Original HP Ink Cartridges reliably deliver standout, durable colour documents and photos page after page. Get the value you expect from cartridges specially designed to work with your HP printer for projects at home, work and school.
Designed to work the first time, every time
Be assured that Original HP Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together. Better results
Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Share your prints with pride
Show off your snapshots. Create store-quality photos you'll be proud to share – using Original HP inks. -
Optional high-yield cartridges offer a better value
Print more for less with optional Original HP high-yield ink cartridges.
- HP 62 - colour (cyan, magenta, yellow) - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Colour (cyan, magenta, yellow)
- Capacity
- 4.5 ml
- Yield
- Up to 165 pages
- Localisation
- Eastern Europe
- Compatible with
- ENVY 5542, 5545, 5640, 5643, 5660, 5663, 7640, 7644; Officejet 200, 250 Mobile, 5740, 5742, 5742 Printer, 5744, 8040, 8040 with Neat
- Shipping Weight
- 0.1 kg
- Localisation
- Eastern Europe
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 1-pack
- Capacity
- 4.5 ml
- Yield
- Up to 165 pages
- Compatible with
- HP ENVY 5542, 5545, 5640, 5643, 5660, 5663, 7640, 7644 , HP Officejet 200, 250 Mobile, 5740, 5742, 5742 Printer, 5744, 8040, 8040 with Neat
