HP 62 Black Ink Cartridge
Quicklinx: 9Q2JWS00 Mfr#: C2P04AE
Type: Ink Cartridge
Technology: [N/A]
More than 50 in stock
£12.57 ex VAT
£15.08 inc VAT
Original HP Ink Cartridges reliably deliver laser-quality, durable documents page after page. Get the value you expect from cartridges specially designed to work with your HP printer for projects at home, work and school.
  • Designed to work the first time, every time
    Be assured that Original HP Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Share your prints with pride
    Show off your printing projects. Create documents you'll be proud to share – using Original HP inks.
  • Optional high-yield cartridges offer a better value
    Print more for less with optional Original HP high-yield ink cartridges.
HP 62 - black - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Compatible with
Envy 5540, 5541, 5542, 5543, 5544, 5545, 5546, 5547, 5548, 5549, 5640, 5642, 5644, 5646, 5660, 5661, 5663, 7640, 7643, 7644, 7645; Officejet 200, 250 Mobile, 5740, 5741, 5742, 5744, 5746, 8040 with Neat
Shipping Width
11.5 cm
Shipping Depth
11.3 cm
Shipping Height
3.7 cm
Shipping Weight
0.1 kg
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
1-pack
Compatible with
HP Envy 5540, 5541, 5542, 5543, 5544, 5545, 5546, 5547, 5548, 5549, 5640, 5642, 5644, 5646, 5660, 5661, 5663, 7640, 7643, 7644, 7645 , HP Officejet 200, 250 Mobile, 5740, 5741, 5742, 5744, 5746, 8040 with Neat
Type: Ink Cartridge
Technology: [N/A]
Brand: HP
Stock Status: In stock
