Proven, flexible, capable: a consistently reliable PC that delivers proven technology, flexible productivity tools, and security features that are designed to provide a capable foundation for your business.
Empower your business
Thrive with technology you can trust. Your choice of Intel processors, the Intel Q43 express chipset, DDR3 Memory and integrated dual display capability help you get the job done. -
Having choices is ideal
A flexible and expandable PC with options that best suit your needs with two available chassis designs and a blend of ports, slots, and bays so you can create a customized solution. -
Easy to deploy and manage
Streamline business processes while lowering IT costs and operating expenses with features that allow for more efficient planning, deployment and transition of PCs. -
Security that's right for you
Essential security features to help protect your physical assets and critical business data. Optional HP ProtectTools modules are available to help you more safely secure your hardware, software, firmware and OS. -
Built to last
With more than 130,000 hours of testing, you get a reliable and durable desktop that can go the distance.
- HP Compaq 6000 Pro - micro tower - Core 2 Duo E8500 3.16 GHz - 4 GB - HDD 500 GB
- Personal computer - micro tower
- Localisation
- Processor
- Intel Core 2 Duo E8500 / 3.16 GHz (Dual-Core)
- Processor Socket
- LGA775 Socket
- Cache Memory
- 6 MB L2 Cache
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-10600
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- HDD 500 GB - SATA 3Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti with LightScribe Technology
- Card Reader
- 22 in 1
- Graphics Controller
- Intel GMA 4500 Dynamic Video Memory Technology 5.0
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- 17.7 cm x 43.1 cm x 37.7 cm
- 9.3 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Personal computer
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.16 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA775 Socket
- Chipset Type
- Intel Q43 Express
- Front Side Bus
- 1333 MHz
Cache Memory
- Installed Size
- L2 Cache - 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1066 MHz
- Rated Memory Speed
- 1333 MHz
- Memory Specification Compliance
- PC3-10600
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total)
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
- Native Command Queuing (NCQ)
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
- Read Speed
- 48x (CD) / 16x (DVD)
- Write Speed
- 48x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
- CD / DVD Rewrite Speed
- 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
- Disc Labeling Technology
- LightScribe Technology
Card Reader
- 22 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Mouse, keyboard
- Integrated
- Ethernet Controller
- Intel 82567LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL)
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
- Slots
- 4 DIMM 240-pin , 1 (total) / 1 (free) x PCI - full-height , 2 (total) / 2 (free) x PCIe x1 - full-height , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 0 (free) x CPU
- 10 x USB 2.0 (4 front, 6 rear) , 1 x audio line-in , 1 x audio line-out , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x VGA , 1 x DisplayPort
- Theft/Intrusion Protection
- ACPI
- HP Smart Buy
- Power supply
- Voltage Required
- Power Provided
- 320 Watt
- 80 PLUS Certification
- 80 PLUS
- Power Factor Correction
Operating System / Software
- OS Provided
- OS Certified
- Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 17.7 cm
- 43.1 cm
- 37.7 cm
- 9.3 kg
- 10 °C
- 35 °C
- 10 - 90%
