HP 600 G3 SFF Intel Core i7100 4GB 500GB Windows 10 Pro
Quicklinx: CP4GWS00 Mfr#: 1HK34ET#ABU
  • Core i3
Powered for business, the HP ProDesk 600 is a highly expandable PC, featuring flexible connectivity, strong security, and comprehensive manageability features in a stylishly redesigned chassis for the modern workplace.
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 600 SFF has two bays, two slots, two M.2 connectors, and configurable video ports in addition to legacy ports.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and simplify management with HP WorkWise, HP’s most advanced smartphone app for PC management.
Powerful options
Power through your day with high-performance 7th Gen Intel® Core™ i3/i5/i7processors unleashed by optional Intel® Optane™ technology, up to 64 GB of DDR4 memory, and optional graphics cards.
Connection hub
With 8 total USB ports, up to three video outputs, and optional Bluetooth™ connectivity, the HP ProDesk 600 SFF becomes a hub for all your devices in the office.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP ProDesk 600 SFF with built-in security, collaboration, and connectivity.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Super secure. Super protected
    HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
  • Get PC images right the first time
    Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
  • Built-in durability
    Rest easy with a PC that goes the distance and is designed to pass HP Total Test Process.
HP ProDesk 600 G3 - SFF Core i3 7100 3.9 GHz - 4 GB - HDD 500 GB - UK
Personal computer - SFF
Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Smart Cache
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
27 cm x 29.6 cm x 9.5 cm
4.53 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 2.0 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, CECP, SEPA
HP Smart Buy
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
90% at 20% Load (115 VAC), 92% at 50% Load (115 VAC), 89% at 100% Load (115 VAC), 91% at 20% Load (230 VAC), 93% at 50% Load (230 VAC), 90% at 100% Load (230 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
27 cm
29.6 cm
9.5 cm
4.53 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (7)
CP4G HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £17.66
CP4G HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £16.46
CP4G HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £39.49
CP4G HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £28.19
CP4G HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £55.31
CP4G HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £77.67
CP4G HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £24.77
Other bundles (4)
CP4G HPE DisplayPort to VGA Adapter In Stock £12.98
CP4G HP USB-C To VGA Adapter In Stock £22.09
CP4G HP Keyed Cable Lock 10mm In Stock £26.40
CP4G HP USB-C to HDMI 2.0 Adapter In Stock £46.71
