HP 600 G3 DM Intel Core i7500T 4GB 500GB Windows 10 Pro
Quicklinx: CP4KWS00 Mfr#: 1CB69ET#ABU
  • Core i5
  • IEEE 802.11n
Powered for business, the HP ProDesk 600 is a highly expandable PC featuring flexible connectivity, strong security, and comprehensive manageability features in a stylishly redesigned chassis for the modern workplace.
Business-ready performance, nicely packaged
Power through your day with high-performance 7th Gen Intel® Core™ i3/i5/i7processors, optional Intel® Optane™ memory and SSDs, and up to 32 GB of DDR4 memory, and HP Turbo Drive G2.
Simple mounting solutions
Easily deploy your Mini behind any ProDisplay for a near zero footprint solution. Mount and secure it almost anywhere with HP’s full ecosystem of DM accessories.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and easily manage devices through Microsoft SCCM using the HP Manageability Integration Kit.
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or Serial Type C™ with DisplayPort™.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP ProDesk 600 Desktop Mini with built-in security, collaboration, and connectivity.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Super secure. Super protected
    HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
  • Get PC images right the first time
    Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation.
  • Maximize network performance
    Greatly improve data, voice, and video communication transfer rates over challenged LAN and Wi-Fi networks.
HP ProDesk 600 G3 - mini desktop Core i5 7500T 2.7 GHz - 4 GB - HDD 500 GB - UK
Personal computer - mini desktop
Intel Core i5 (7th Gen) 7500T / 2.7 GHz (up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17.7 cm x 17.47 cm x 3.42 cm
1.21 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express Mini Card (M.2)
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
6 x USB 3.1 Gen 1 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x aerial
HP Desktop Mini Vertical Chassis Stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, CCC, CECP, SEPA
HP Smart Buy
Power adapter
Power Provided
65 Watt
Efficiency
89% (115VAC), 89% (230VAC)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
17.7 cm
17.47 cm
3.42 cm
1.21 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (6)
CP4K HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £17.66
CP4K HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £39.49
CP4K HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £28.19
CP4K HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £55.31
CP4K HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £77.67
CP4K HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £24.77
Other bundles (3)
CP4K HP USB-C To VGA Adapter In Stock £22.09
CP4K HP Keyed Cable Lock 10mm In Stock £26.40
CP4K HP USB-C to HDMI 2.0 Adapter In Stock £46.71
