Powered for business, the HP ProDesk 600 is a highly expandable PC featuring flexible connectivity, strong security, and comprehensive manageability features in a stylishly redesigned chassis for the modern workplace.
Business-ready performance, nicely packaged
Power through your day with high-performance 7th Gen Intel® Core™ i3/i5/i7processors, optional Intel® Optane™ memory and SSDs, and up to 32 GB of DDR4 memory, and HP Turbo Drive G2.
Simple mounting solutions
Easily deploy your Mini behind any ProDisplay for a near zero footprint solution. Mount and secure it almost anywhere with HP’s full ecosystem of DM accessories.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and easily manage devices through Microsoft SCCM using the HP Manageability Integration Kit.
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or Serial Type C™ with DisplayPort™.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful HP ProDesk 600 Desktop Mini with built-in security, collaboration, and connectivity. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager. -
Super secure. Super protected
HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users. -
Get PC images right the first time
Improve the quality and security of custom Windows images with HP Image Assistant which assists ITDMs with image creation, identifies problems, and provides recommendations and remediation. -
Maximize network performance
Greatly improve data, voice, and video communication transfer rates over challenged LAN and Wi-Fi networks.
- HP ProDesk 600 G3 - mini desktop Core i5 7500T 2.7 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7500T / 2.7 GHz (up to 3.3 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 630
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17.7 cm x 17.47 cm x 3.42 cm
- 1.21 kg
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q270
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express Mini Card (M.2)
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
- 6 x USB 3.1 Gen 1 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x aerial
- Included Accessories
- HP Desktop Mini Vertical Chassis Stand
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- ACPI, CCC, CECP, SEPA
- HP Smart Buy
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89% (115VAC), 89% (230VAC)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
Sustainability Information
- ENERGY STAR Certified
- 17.7 cm
- 17.47 cm
- 3.42 cm
- 1.21 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (7)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £32.96 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £27.34 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £34.13 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £69.44 |
HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site | In Stock | £57.67 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site | In Stock | £80.03 |
HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only | In Stock | £24.77 |
Other bundles (2)
HPE USB to Serial Port Adapter | In Stock | £13.88 |
HP USB-C To VGA Adapter | In Stock | £22.93 |
