HP 532sf 32" 1920x1080 7ms VGA HDMI LED Monitor
Quicklinx: J8QHWS00 Mfr#: 94F50AA#ABU
£177.97 ex VAT
£213.56 inc VAT
Get lost in any passion project with the HP Series 5 31.5-inch FHD Monitor. Its sleek, thin-and-light design gives you the flexibility to enjoy entertainment while vibrant color and deep contrast ratio lets you see everything as it was meant to be seen. Enhance your screen time and your pastime with a higher refresh rate for a screen-tear-free experience.
HP 532sf - 5 Series - LED monitor - Full HD (1080p) - 32"
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1853284
Energy Class
Class D
Power Consumption (On mode)
20 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.36 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 10000000:1 (dynamic)
Response Time
7 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 40%
Voltage
AC 100-240 V (50/60 Hz)
Silver stand
71.03 cm x 21.66 cm x 49.48 cm
5.1 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
190 kg carbon emissions
VCCI, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, ICES, cTUVus, TUV Bauart, CEC, KC, ERP, CECP, CEL, EAC, CEL Grade 1, BIS, low halogen, TUV Rheinland Flicker Free Certification, NRCS, K-MEPS, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TUV flicker free, Works With Chromebook (WWCB) certified, WW application, Korea MEPS, Ukraine NSoC, Eyesafe Certification, UAE RoHS, Ukraine CoC, UAE ECAS
1-year warranty
Display Type
Energy Class
Class D
Diagonal Size
32"
Viewable Size
31.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.36 mm
Pixel Per Inch
70
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Flicker Free technology, 3-sided micro-edge, Low Blue Light technology, HP Eye Ease, True 8-bit
Silver stand
71.03 cm x 21.66 cm x 49.48 cm - with stand
5.1 kg
2 x HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
Security lock slot (cable lock sold separately), detachable stand
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
20 W
20 kWh/1000h
Power Consumption (Typical)
24.6 Watt
Power Consumption (Max)
30.4 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center
Dimensions & Weight Details
With stand - width: 71.03 cm - depth: 21.66 cm - height: 49.48 cm - weight: 5.1 kg , Without stand - width: 71.03 cm - depth: 4.02 cm - height: 41.46 cm
Shipping Width
82.3 cm
Shipping Depth
14 cm
Shipping Height
52.7 cm
Shipping Weight
9 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
103
Logistics (kg CO2e)
2
Use (kg CO2e)
78
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
190
Limited warranty - 1 year
5 °C
35 °C
20 - 80% RH (non-condensing)
J8QH HP Care Pack Pick-Up and Return Service Extended Service Agreement 3 Years In Stock £16.61
Brand: HP
