HP 524pm Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Conferencing Monitor
Quicklinx: J71ZWS00 Mfr#: 9E0G9UT#ABU
24 In Stock
£264.68 ex VAT
£317.61 inc VAT
Feel confident collaborating effortlessly with the HP Series 5 Pro 23.8" FHD USB-C Conferencing Monitor. Achieve distraction-free meetings, wherever you work, with advanced AI. Settle into total comfort thanks to a customizable setup.
HP 524pm - Series 5 Pro - LED monitor - Full HD (1080p) - 24" - Smart Buy
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/2047552
Energy Class
Class D
Daisy Chaining
KVM Switch, USB 3.2 Gen 1 hub, 4 x 3W speakers, USB PD 100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1500:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Webcam
5 Megapixel - 2592 x 1944 at 30 fps
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Jet black, natural silver (stand)
53.94 cm x 18.95 cm x 50.32 cm
9.5 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, KCC, WEEE, PSE Mark, ICES, cTUVus, CEC, EMF, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA, BIS, NRCS, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Ukraine Energy Label, TGM, TUV low blue light, TUV flicker free, Korea MEPS, Australian-New Zealand DoC
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Daisy Chaining
Built-in Devices
USB Power Delivery
100 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 115 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Flicker Free technology, Micro Edge, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 3-sided borderless, Out-of-Band MAC Address Pass Through (MAPT), Out-of-Band Wake on LAN (WoL), PXE Boot, In-Band MAC Address Pass Through (MAPT)
53.94 cm x 18.95 cm x 50.32 cm - with stand
9.5 kg
Built-in Webcam
Sensor Resolution
5 Megapixel
Max Video Resolution
Windows Hello compatible, IR sensor, 80° diagonal field of view, -20° / +5° tilt, pop-up privacy, AI noise reduction, auto lock and awake, Poly Studio
DisplayPort , DisplayPort output , HDMI , USB-B upstream , 3 x USB 3.2 Gen 1 downstream (1 charging) , USB-C 3.2 Gen 1/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 100W) , USB-C 3.2 Gen 1 (power up to 15W) , Audio line-in/out
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wake on LAN, detachable stand
1 x USB-A to USB-B cable , 1 x DisplayPort cable , 1 x USB-C cable
Backlight Life
30,000 hours
Software Certification
Zoom Certified
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
14 kWh/1000h
Power Consumption (Typical)
33 Watt
Power Consumption (Max)
223 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Client Management Script Library, HP Display Center
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 18.95 cm - height: 50.32 cm - weight: 9.5 kg , Without stand - width: 53.94 cm - depth: 1.86 cm - weight: 4.99 kg
Shipping Width
62.1 cm
Shipping Depth
14 cm
Shipping Height
39.3 cm
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
Brand: HP
