Feel confident collaborating effortlessly with the HP Series 5 Pro 23.8" FHD USB-C Conferencing Monitor. Achieve distraction-free meetings, wherever you work, with advanced AI. Settle into total comfort thanks to a customizable setup.
Sharp & Privacy Ready 5MP Webcam
The Poly Studio 5MP pop-up tiltable webcam delivers superb camera quality and has advanced collaboration tools. Plus, a Time of Flight proximity sensor enables Auto Lock and Awake for on demand privacy. -
AI Noise Reduction
Upgrade your conference call experience with HP AI-based noise reduction filters. Limit distractions including dogs, sirens, construction, and other meetings so you're heard loud and clear no matter what's happening around you. -
Intuitive Conferencing Experience
Collaborate confidently with a host of enhanced camera software features. Auto framing keeps you front and center and background blur minimizes distractions. -
Integrated 4 x 3W Down Firing Speakers
The integrated, down firing 4 x 3W speakers deliver crystal-clear audio without adding additional cables or external speakers to your desk. Never miss a word with this clean desk solution. -
Meetings Made Effortless
Seamlessly collaborate with a Microsoft Teams compatible and Zoom Certified monitor. Access conferencing controls quickly with control buttons on the display. -
FHD Resolution
Focus on the finer details and enjoy sharp visuals and crystal clear images with the 1920 x 1080 FHD resolution on this 23.8" diagonal monitor.
- HP 524pm - Series 5 Pro - LED monitor - Full HD (1080p) - 24" - Smart Buy
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2047552
- Energy Class
- Class D
- Daisy Chaining
- KVM Switch, USB 3.2 Gen 1 hub, 4 x 3W speakers, USB PD 100 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Built-in Webcam
- 5 Megapixel - 2592 x 1944 at 30 fps
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Jet black, natural silver (stand)
- 53.94 cm x 18.95 cm x 50.32 cm
- 9.5 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- VCCI, BSMI, GS, NOM, TUV S, CB, CCC, PSB, FCC, KCC, WEEE, PSE Mark, ICES, cTUVus, CEC, EMF, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA, BIS, NRCS, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Ukraine Energy Label, TGM, TUV low blue light, TUV flicker free, Korea MEPS, Australian-New Zealand DoC
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Daisy Chaining
- Built-in Devices
- USB Power Delivery
- 100 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 93
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 115 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, Micro Edge, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 3-sided borderless, Out-of-Band MAC Address Pass Through (MAPT), Out-of-Band Wake on LAN (WoL), PXE Boot, In-Band MAC Address Pass Through (MAPT)
- 53.94 cm x 18.95 cm x 50.32 cm - with stand
- 9.5 kg
Built-in Webcam
- Sensor Resolution
- 5 Megapixel
- Max Video Resolution
- Windows Hello compatible, IR sensor, 80° diagonal field of view, -20° / +5° tilt, pop-up privacy, AI noise reduction, auto lock and awake, Poly Studio
- DisplayPort , DisplayPort output , HDMI , USB-B upstream , 3 x USB 3.2 Gen 1 downstream (1 charging) , USB-C 3.2 Gen 1/DisplayPort 1.4 Alt Mode with Power Delivery (power up to 100W) , USB-C 3.2 Gen 1 (power up to 15W) , Audio line-in/out
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wake on LAN, detachable stand
- Cables Included
- 1 x USB-A to USB-B cable , 1 x DisplayPort cable , 1 x USB-C cable
- Backlight Life
- 30,000 hours
- Software Certification
- Zoom Certified
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 33 Watt
- Power Consumption (Max)
- 223 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Client Management Script Library, HP Display Center
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 18.95 cm - height: 50.32 cm - weight: 9.5 kg , Without stand - width: 53.94 cm - depth: 1.86 cm - weight: 4.99 kg
- Shipping Width
- 62.1 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 39.3 cm
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
HP DM V4+ VESA Sleeve | In Stock | £25.22 |
