HP 524pf Series 5 Pro 24" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: J5QDWS00 Mfr#: 9D9L6UT#ABU
More than 50 In Stock
£113.01 ex VAT
£135.61 inc VAT
Get more out of your workday with the HP Series 5 Pro 23.8" FHD Monitor. Create the setup that works for the way you work, wherever you work, with refined visual clarity and adjustable comfort built into a sleek, modern design.
HP 524pf - Series 5 Pro - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1949552
Energy Class
Class C
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.28 mm
Brightness
350 cd/m²
Contrast Ratio
1500:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Jet black, silver (stand)
53.94 cm x 18.95 cm x 50.32 cm
4.9 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
VCCI, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, ICES, cTUVus, TUV Bauart, CEC, KC, ERP, CECP, CEL, EAC, CEL Grade 1, BIS, low halogen, NRCS, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TUV flicker free, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine NSoC, UAE RoHS, Ukraine CoC, Eyesafe Certified 2.0, UAE ECAS
3-year warranty
Display Type
Energy Class
Class C
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.28 mm
Pixel Per Inch
93
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 120 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Flicker Free technology, 3 Side Borderless Design, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
53.94 cm x 18.95 cm x 50.32 cm - with stand
4.9 kg
HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.2 Gen 1 (1 charging) , USB-B
Mechanical
Tilt Angle
-5/+23
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-A to USB-B cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot / HP Business PC Security Lock slot
Input Voltage
12 kWh/1000h
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 18.95 cm - height: 50.32 cm - weight: 4.9 kg , Without stand - width: 53.94 cm - depth: 4.72 cm - height: 31.43 cm - weight: 3.4 kg
Shipping Width
62.1 cm
Shipping Depth
14 cm
Shipping Height
39.3 cm
Shipping Weight
7.4 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
Brand: HP
