Get more out of your workday with the HP Series 5 Pro 23.8" FHD Monitor. Create the setup that works for the way you work, wherever you work, with refined visual clarity and adjustable comfort built into a sleek, modern design.
                FHD ResolutionFocus on the finer details and enjoy sharp visuals and crystal clear images with the 1920 x 1080 FHD resolution on this 23.8" diagonal monitor.
                IPS TechnologyNo matter where you are or sit, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles.
                100 Hz Refresh RateWith a 100 Hz refresh rate this monitor is capable of clear details, smoothly moving from frame to frame, allowing for fast split-second reaction time.
                More ContrastSee the nuanced differences of color, shadow, and highlights thanks to the enhanced 1500:1 contrast ratio.
                High Brightness350 nits of brightness lets you see clearly. Enhance your visual performance for work or simply enjoying entertainment.
                100% sRGB Color GamutEnjoy highly accurate colors on screen with 100% sRGB. This HP monitor provides ideal color reproduction with minimal effort.
- HP 524pf - Series 5 Pro - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1949552
- Energy Class
- Class C
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.28 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Jet black, silver (stand)
- 53.94 cm x 18.95 cm x 50.32 cm
- 4.9 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- VCCI, BSMI, NOM, WHQL, CB, CCC, FCC, ISO 9241-307, KCC, ICES, cTUVus, TUV Bauart, CEC, KC, ERP, CECP, CEL, EAC, CEL Grade 1, BIS, low halogen, NRCS, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TUV flicker free, Works With Chromebook (WWCB) certified, Korea MEPS, Ukraine NSoC, UAE RoHS, Ukraine CoC, Eyesafe Certified 2.0, UAE ECAS
- 3-year warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.28 mm
- Pixel Per Inch
- 93
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 120 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, 3 Side Borderless Design, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
- 53.94 cm x 18.95 cm x 50.32 cm - with stand
- 4.9 kg
- HDMI (HDCP) , DisplayPort (HDCP) , 4 x USB 3.2 Gen 1 (1 charging) , USB-B
Mechanical
- Tilt Angle
- -5/+23
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-A to USB-B cable
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot / HP Business PC Security Lock slot
- Input Voltage
- Power Consumption SDR (On mode)
- 12 kWh/1000h
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 18.95 cm - height: 50.32 cm - weight: 4.9 kg , Without stand - width: 53.94 cm - depth: 4.72 cm - height: 31.43 cm - weight: 3.4 kg
- Shipping Width
- 62.1 cm
- Shipping Depth
- 14 cm
- Shipping Height
- 39.3 cm
- Shipping Weight
- 7.4 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
|  | HP DM V4+ VESA Sleeve | In Stock | £25.22 |
