HP 500B E5800 2GB 320GB DVD-RAM Windows 7 Professional
HP 500B Microtower-PC
Quicklinx: 7CQHWS00 Mfr#: XP033EA#ABU
  • Pentium
  • Microsoft Windows 7 Professional 64-bit Edition
Small Business Basics. Let the HP 500B Business PC take your business to new places at a price that won't break your bank. Stimulate your work day with a small business PC designed to suit your needs and your budget.
  • Basic design
    The HP 500B is designed to be easy to setup and easy to use. Get to work right out of the box with the functionality you need for small business computing at its basics and operate effectively from day one.
  • Essential technology
    Proven Intel processors, Genuine Windows 7 Operating System, Intel chipset and Graphics Media Accelerator, a choice of optical drives, hard drives up to 640GB, and up to 4 GB DDR3 SDRAM memory.
  • Need options?
    PCIe slots to help you get the job done with options like discrete graphics cards.
  • Built to last
    With more than 113,000 hours of testing, you get a reliable and durable desktop that can go the distance.
HP 500B - micro tower Pentium E5800 3.2 GHz - 2 GB - HDD 320 GB
Personal computer - micro tower - boot without keyboard or mouse, wake on USB
Intel Pentium E5800 / 3.2 GHz (Dual-Core)
Processor Socket
LGA775 Socket
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
2 GB (installed) / 4 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 320 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti with LightScribe Technology
Graphics Controller
Intel GMA X4500 Dynamic Video Memory Technology 5.0
Audio Output
Integrated
10Mb LAN, 100Mb LAN
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
HP Power Manager 2.0, HP Total Care Advisor, Microsoft Office 2010 Starter, Corel WinDVD 8, HP ProtectTools Security Software Suite SMB, Mozilla Firefox for HP Virtual Solutions
16.6 cm x 42.8 cm x 38.4 cm
10.2 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Processor / Chipset
CPU
Intel Pentium E5800
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA775 Socket
Chipset Type
Intel G41 Express
Front Side Bus
800 MHz
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
Effective Memory Speed
1066 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
2 (Total)
Unbuffered
Hard Drive
HDD
1 x 320 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
48x (CD) / 16x (DVD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Disc Labeling Technology
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA
Audio Output
Integrated
Max Sampling Rate
96 kHz
High Definition Audio
Input Device
Mouse, keyboard
Integrated
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8103EL
Ethernet, Fast Ethernet
Wake on LAN (WoL), ACPI support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
2 DIMM 240-pin , 1 (total) / 1 (free) x PCI - full-height , 2 (total) / 2 (free) x PCIe x1 - full-height , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 0 (free) x CPU
6 x USB 2.0 (2 front, 4 rear) , 2 x audio line-in (1 in front) , 2 x audio line-out (1 in front) , 1 x microphone , 1 x LAN , 1 x VGA
Boot without keyboard or mouse, wake on USB
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
ACPI 2.0, APM 1.2
Power supply
Power Provided
300 Watt
Operating System / Software
OS Provided
OS Certified
SUSE Linux Enterprise Desktop 11
Software
16.6 cm
42.8 cm
38.4 cm
10.2 kg
10 °C
35 °C
10 - 90% (non-condensing)
