HP 4GB DDR4-2400 SODIMM
Quicklinx: CTB9WS00 Mfr#: Z9H55AT
Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP PCs.
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your PC.
  • Flexible, fast scalability
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs.
  • Supported by HP
HP - DDR4 - module - 4 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Unbuffered
Voltage
1.2 V
HP Z9H55AT
Manufacturer Selling Program
HP Smart Buy
Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite; EliteDesk 800 G3 (SO-DIMM); EliteOne 1000 G1, 1000 G2, 800 G3; ProDesk 400 G3 (SO-DIMM), 600 G3 (SO-DIMM); ProOne 400 G3, 440 G3, 600 G3
4 GB
Upgrade Type
System specific
HP Z9H55AT
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
HP Smart Buy
HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite , HP EliteDesk 800 G3 (SO-DIMM) , HP EliteOne 1000 G1, 1000 G2, 800 G3 , HP ProDesk 400 G3 (SO-DIMM), 600 G3 (SO-DIMM) , HP ProOne 400 G3, 440 G3, 600 G3
