HP 4GB DDR4-2133 ECC REG RAM
Quicklinx: CKLZWS00 Mfr#: J9P81AT
Boost the capabilities of your HP Workstation with registered DDR4 memory from HP. Get high reliability and cost savings on high-capacity modules vs. unregistered memory.
  • Maximize the newest processors
    Keep the newest multi-core processors performing at their peak with fast memory. Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between several open applications.
  • Benefit from integrated ECC
    Help avoid errors that can corrupt data sets and introduce system issues when you select ECC memory, which includes Error Checking and Correcting technology to correct single-bit memory errors.
  • Get HP-tested reliability
    Ensure all of your memory characteristics match by upgrading with HP-branded memory that's been tested at the component level and to ensure seamless system-level integration with HP products.
  • Supported by HP
    Protect your investment with a warranty that is backed the same award-winning HP service and support you get for your workstation.
HP - DDR4 - module - 4 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
HP J9P81AT
Manufacturer Selling Program
HP Smart Buy
1-year warranty
Workstation Z440, Z640, Z840
4 GB
Upgrade Type
System specific
HP J9P81AT
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Voltage
1.2 V
HP Smart Buy
1-year warranty
HP Workstation Z440, Z640, Z840
