HP 490 G3 MT Intel Core i7-6700 4GB 1TB Windows 10 Professional
Quicklinx: CH22WS00 Mfr#: Z2J34ET#ABU
  • Core i7
Give your business the strong foundation it needs for growth with the reliable HP ProDesk 490 micro tower PC. Designed with essential security and manageability features, the HP ProDesk 490 helps keep your business growing.
  • Let nothing stand in your way
    Help protect from today's security threats and maximize management and productivity features for business with Windows 10 Pro.
  • Simplify device management
    Reduce the complexity of administration. Windows 10 Pro manageability features help you easily manage assets.
  • Communication made easy
    Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing Keyboard.
  • Can grow with work demands
    Extend the life of your purchase. Using the tool-less chassis this easily upgradable platform features easily upgradeable memory, storage, and graphics to meet diverse and growing business needs.
  • Connect to more capabilities
    Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 490/498 MT allows you to connect two optional HP Pro Displays right out-of-the-box.
  • Green with envy
    Reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified configurations.
HP ProDesk 490 G3 - micro tower - Core i7 6700 3.4 GHz - vPro - 4 GB - HDD 1 TB - UK
Personal computer - micro tower
Platform Technology
Intel vPro Platform
Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
16.5 cm x 35.5 cm x 35.88 cm
7.05 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H170
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Value
USB
Localization & Layout
Mouse
Mouse Name
HP USB Mouse
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x external , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
2 (total) / 2 (free) x PCIe 3.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin
6 x USB 3.0 (2 front, 4 rear) , 2 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
300 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Sustainability Information
ENERGY STAR Certified
16.5 cm
35.5 cm
35.88 cm
7.05 kg
10 °C
35 °C
10 - 90% (non-condensing)
