Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C G2 Power Adapter.
  • Simple to use
    Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
  • Easy to carry and store
    Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
  • World-class support
    Rest easy with a one-year limited warranty.
HP USB-C G2 - power adapter - 45 Watt
Power adapter - external
English / United Kingdom
Input Voltage
AC
Power Capacity
45 Watt
Input Connectors
24 pin USB-C
6.2 cm x 6.2 cm x 2.85 cm
1-year warranty
Input Voltage
AC
Input Connectors
24 pin USB-C
Power Capacity
45 Watt
Limited warranty - 1 year
6.2 cm
6.2 cm
2.85 cm
