HP 4300 SFF Intel® Core™ i3-3220 Processor, 4GB, 500GB, DVD±RW, Windows 7 Professional 64-bit
Quicklinx: 8990WS00 Mfr#: LX819EA#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
Strong PC performance, intelligent PC design. Introducing the HP Compaq Pro 4300 Small Form Factor; a business-reliable PC platform designed to match your everyday needs and deployment functions.
  • Smart design, strong performance
    Meet commercial-grade deployment scenarios with the Intel H61 Express chipset and a 2nd and 3rd generation Intel Core processor family. Bring work to life with integrated Intel HD Graphics.Increase your desktop real-estate with support for dual-monitor set-up through VGA and DVI-D outputs.Customizable expansion options include two PCI low profile slots, a PCI Express x1 slot and a PCI Express x16 to support discrete graphics performance. The HP Compaq Pro 4300 SFF also offers SATA hard drives up to 1 TB.Boost storage space and work proficiently with support for DDR3 SDRAM memory technology for an energy efficient, memory expansion solution.Industry standard ports and connectors include four front and four rear USB 2.0 ports, Serial, PS/2, standard VGA and DisplayPort and RJ45 ports. Choose to add an optional parallel port, eSATA port or second serial port for even more flexibility.
  • Simple management and control
    Develop your own PC deployment functions with administrative passwords through HP BIOS, and secure your unit with the HP Chassis Security Kit.
  • Designed with the environment in mind
    Help lower your operational costs and overall eco-footprint with an HP business PC that's ENERGY STAR qualified, EPEAT Gold registered and designed with low halogen materials.
  • Backed by HP
    Gain peace of mind with a 12-month lifecycle stability commitment and standard, 3-year limited warranty from HP. Additional coverage is available through HP Care Pack services.
HP Compaq Pro 4300 - SFF - Core i3 3220 3.3 GHz - 4 GB - HDD 500 GB
Personal computer - small form factor - system password, power-on password, serial port I/O control, USB port control, DriveLock
Language: English / region: United States
Intel Core i3 (3rd Gen) 3220 / 3.3 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 2500 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Flash Player, HP Help and Support, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, Microsoft Office 2010 Starter, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, HP Setup 9.0, Microsoft Advantage Program
33.8 cm x 37.85 cm x 10 cm
7.6 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Speaker
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H61 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total)
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD-R DL) / 12x (DVD+R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DVI
Max Monitors Supported
2
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Integrated
Ethernet Controller
Broadcom BCM57788
Remote Management Protocol
DMI 2.0, ASF 2.0
Wake on LAN (WoL), ACPI support, PXE support
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, WfM 2.0
Bays
1 (total) / 0 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5" , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 - low-profile , 1 (total) / 1 (free) x PCIe x1 - low-profile , 2 (total) / 2 (free) x PCI - low-profile
8 x USB 2.0 (4 front, 4 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x serial , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D
System password, power-on password, serial port I/O control, USB port control, DriveLock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
ACPI, RoHS, WEEE
Power supply
Power Provided
240 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
OS Certified
SUSE Linux Enterprise Desktop 11
Software
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
33.8 cm
37.85 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
