HP 400G3 AIO NT I57500 20" 4GB/256GB W10P
Quicklinx: D8ZYWS00 Mfr#: 2KL21EA#ABU
  • Core i5
  • IEEE 802.11n
Easy-to-deploy, sleek, and feature-rich, the HP ProOne 400 20" All-in-One PC with business-class collaboration and security features is a sound investment.
  • Let nothing stand in your way
    Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ProOne 400 AiO.
  • Super secure. Super protected
    Guard your data, device and identity with HP Client Security Suite Gen3.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Several deployment options
    Pair this space-saving AiO with the mounting option to fit your workspace and use case.
  • Cut out the chatter
    Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
HP ProOne 400 G3 - all-in-one - Core i5 7500T 2.7 GHz - 4 GB - SSD 256 GB - LED 20" - UK
Personal computer - all-in-one
Intel Core i5 (7th Gen) 7500T / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s - triple-level cell (TLC)
Optical Storage
DVD-Writer
Card Reader
Monitor
20" - LED - 1600 x 900 (HD+) - 16:9
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Camera
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP SoftPaq Download Manager, HP Client Catalog, HP BIOS Config Utility, HP System Software Manager, HP MIK for Microsoft SCCM (free download)
49.77 cm x 5.8 cm x 34.7 cm
5.51 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year
Personal computer
Product Form Factor
All-in-one - with Easel Stand
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Triple-level cell (TLC)
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
LED - IPS
Diagonal Size
20"
Native Resolution
1600 x 900 (HD+)
Widescreen Display
Image Aspect Ratio
16:9
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
1 Megapixel
Resolution
1280 x 720
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Dual stream (2x2)
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 , 1 (total) / 1 (free) x M.2 Card - 2230/2280
4 x USB 3.0 , 2 x USB 2.0 , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Common Criteria EAL4+, low halogen
Power adapter
Power Provided
90 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
49.77 cm
5.8 cm
34.7 cm
5.51 kg
Warranties (1)
D8ZY HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £14.86
Monitors (1)
D8ZY HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
Other bundles (3)
D8ZY HPE DisplayPort To VGA Adapter In Stock £13.72
D8ZY HPE DisplayPort to VGA Adapter In Stock £16.34
D8ZY HP USB-C to DisplayPort Adapter In Stock £23.53
