HP 400 G4 MT Intel Core i5-7500 4GB 500GB Windows 10 Pro
Quicklinx: CP4BWS00 Mfr#: 1EY28ET#ABU
  • Core i5
Designed to fit the modern workspace now and in the future, the small, reliable, and secure HP ProDesk 400 SFF is a powerful PC with performance, that's scalable to grow with the business.
Powerful options
Power through your day with high-performance 7th Gen Intel® Core™ i3/i5/i7processors unleashed optional Intel® Optane™ memory and SSDs, up to 32 GB of DDR4 memory, and discrete graphics.
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 400 MT has three bays and three full-height slots, and optional legacy ports to connect to multiple HP displays.
Connection hub
With eight total USB ports, two video outputs, and optional Bluetooth™ connectivity, the HP ProDesk 400 MT becomes a hub for all your devices in the office.
Tested and ready
The reliable HP ProDesk 400 MT experienced 120,000 hours of the HP Total Test Process and now has an optional dust filter to help extend the life of your PC by reducing airborne particulate intake in the most demanding work environments.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 MT with built-in security, collaboration, and connectivity.
  • Super secure. Super protected
    HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Convenient, always-on, customized, free support
    Enjoy always-on, included self-help support built right into your PC, for the life of your PC.
  • Built-in durability
    Rest easy with a PC that goes the distance and is designed to pass HP Total Test Process.
HP ProDesk 400 G4 - micro tower Core i5 7500 3.4 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (up to 3.8 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications, HP Driver Packs (free download)
17 cm x 27.4 cm x 33.8 cm
5.47 kg
Manufacturer Selling Program
HP Smart Buy
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , Internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height (x4 mode) , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-height
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 (two of them with wake functionality) , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, Common Criteria EAL4+
HP Smart Buy
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
17 cm
27.4 cm
33.8 cm
5.47 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (1)
CP4B HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £25.89
Other bundles (2)
CP4B HPE DisplayPort to VGA Adapter In Stock £21.98
CP4B HP Keyed Cable Lock 10mm In Stock £26.40
