The HP 350 Notebook balances affordable style with productivity, that's perfect for everyday computing.
Durable design that keeps up with the demands of mobile use
Built with durability in mind – inside and out – to meet the needs of professionals on the move.Impact and bumps happen. HP 3D DriveGuard helps protect your data when you're on the go by sensing sudden movement and protecting the hard drive.Help protect sensitive electronics and key components from minor spills with a thin layer of Mylar film under the keyboard.HP CoolSense technology automatically adjusts your notebook's temperature based on usage and conditions. It keeps the notebook cool for your comfort.With a user replaceable battery, you have the convenience of easy maintenance. -
Powered for business
Gain the tools you need to stay in the driver's seat at work. From leading processors to Windows 8.1 technology, you're ready for work.Get up to 1TB hard disk drive for storing documents, images, videos, and more.Get more done with the new fast and fluid Windows 8.1.Confidently tackle tasks and projects with the power of the latest 4th generation Intel Core i3/i5 dual-core processors.Immerse yourself in stunning visuals thanks to AMD Radeon discrete graphics and 2GB of video memory. -
Connect without hassles
Say goodbye to dongles and have all the connections you need, including VGA display, HDMI, Ethernet, USB ports, and an optional built in DVD drive.Connect with colleagues via the Internet and email at the office or your favorite hotspots with Wi-Fi CERTIFIED WLAN.Print from your favorite hotspot or when you have internet access with HP ePrint. Now you can print without the cables.Face-to-face conversations are considered to be more productive. The HD Webcam makes them possible even in low light.
- HP 350 G1 Notebook - 15.6" - Intel Core i5 - 4210U - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Processor
- Intel Core i5 (4th Gen) - 4210U / 1.7 GHz, up to 2.7 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4400
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 4-cell - up to 8.5 hours
- Silver
- 38.4 cm x 26.1 cm x 2.31 cm
- 2.3 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4210U / 1.7 GHz
- Max Turbo Speed
- 2.7 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- HD anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC3201-GR
- High Definition Audio, DTS Sound
Input
- Keyboard, touchpad
- Numeric Keypad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- Gigabit Ethernet
- Remote Management Protocol
- SNMP 2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED
- Technology
- 4-cell Lithium Ion
- Capacity
- 41 Wh
- Run Time
- Up to 8.5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 / 19.5 V
Connections & Expansion
- VGA , HDMI , Headphone/microphone combo jack , LAN , 2 x USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- HP CoolSense, CyberLink YouCam DE, HP SimplePass Identity Protection, Intel Small Business Advantage, Recovery Manager Installer, McAfee Internet Security 2013 (60 days subscription), Getting Started guide with Windows 8.1
- Silver
- Security lock slot (cable lock sold separately), HP 3D DriveGuard
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 2.3 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
