HP 32A HV Core Only Modular Power Distribution Unit
Quicklinx: 73MNWS00 Mfr#: 252663-B33
With simple 0U and 1U installation options, HPE Basic Power Distribution Units are available in multiple form factors allowing you to configure access to power in your rack where you need it the most. HPE Basic PDUs provide a low-profile single-piece design allowing easy access to rear devices for maintenance. Vertical PDUs can be installed on either side of the rack with outlets facing the back of the rack for easy access and improved clearance. For higher power density configurations, they can be installed side by side on both sides of the rack with the outlets facing towards the center. Horizontal/Modular PDUs offer a modular architecture designed for data center customers who want to maximize power distribution and space efficiencies. The Control Unit or core can be mounted in any 1U space or in 0U space on the side of HPE Racks between the RETMA rails. Extension Bars mount directly to the frame so you can configure access to power where you need it.
  • Powerfully Built Power Distribution, Because no two Environments are the Same
    HPE Basic Power Distribution Units are backed by a 3-year warranty. Quality, guaranteed.Premium materials and robust construction guarantee power continuity and maintained performance at elevated temperatures.HPE Basic Power Distribution Units include vertical and horizontal models with power output options ranging from 1.9kVA to 22kVA.Single and three-phase models to meet all your facility power needs.
  • Our Basic PDUs get Power where you Need it to Go – and Keep it There
    HPE Basic Power Distribution Units Horizontal/Modular PDU Models can be installed in any U position in your rack.Integrated cord retention to connect the right cord to the right outlet, quickly and easily.
  • Vertical PDU Models use Button and Keyhole Mounting for Simple Drop in Install
    HPE Basic Power Distribution Units vertical form factor models have a wide range of single and three-phase options providing up to 22kVA of output power.Mounts vertically on either side in the rear of the rack using industry standard button and keyhole mounting. Standard mounting faces the outlet towards the rear of the rack preventing interference in the maintenance zone between rear RETMA rails.Using the optional configuration of facing the outlets into the rack, multiple PDUs can be mounted on one side of the rack for higher power density.
  • Getting Power Where it Needs to go has Never Been Easier, from Purchase to Prime Time
    HPE Basic Power Distribution Units have a wide range of mounting options to fit every application. Power where you need it, plus more room for compute.Highest-density PDUs on market means more power and less headache for even the most demanding compute applications.Tool-less installation, low profile and modular extensions simplify configuration and reduce time to deployment.HPE Foundation Care means your power isn't the only thing that's protected – the warranty from your HPE servers extends to your PDUs.
HPE High Voltage Core Modular Power Distribution Unit Zero-U/1U - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.6 m
8.2 kg
Input Connectors
1 x power IEC 60309 32A
Output connectors
4 x power IEC 60320 C19
44.5 cm x 14.2 cm x 4.1 cm
3-year warranty
UPS R/T3000 G2, R1500 G3, R5000; BLc7000 Platinum Single-Phase Enclosure; ProLiant DL120 Gen9, DL160 Gen8, DL160 Gen9, DL180 Gen9, DL20 Gen9, DL360 Gen9, DL360p Gen8, DL380 Gen9, DL60 Gen9, DL80 Gen9, e2000 G6, ML150 Gen9, ML350 Gen9; Rack; UPS R12000, R7000, R8000; HPE 3PAR StoreServ 10XXX
Cord Length
3.6 m
Input Voltage Range
AC 200 - 240 V
Frequency Required
50/60 Hz
Input Connectors
Max Electric Current
32 A
Power cable - integrated - 3.6 m
Rack Mounting Kit
Included
Limited warranty - 3 years
10 °C
50 °C
10 - 90%
44.5 cm
14.2 cm
4.1 cm
8.2 kg
HP UPS R/T3000 G2 Detachable Cord High Voltage, R1500 G3, R5000, T1000 G3, T1500 G3, T750 G2 , HPE BLc7000 Platinum Single-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 OneView Licenses , HPE BLc7000 Single-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE BLc7000 Three-Phase Enclosure w/6 Power Supplies and 10 Fans w/16 Insight Control Environment Licenses , HPE ProLiant DL120 Gen9, DL120 Gen9 Entry, DL160 Gen8, DL160 Gen8 Entry, DL160 Gen8 Performance, DL160 Gen9, DL160 Gen9 Base, DL160 Gen9 Entry, DL160 Gen9 Performance, DL180 Gen9, DL180 Gen9 Base, DL180 Gen9 Entry, DL180 Gen9 Storage, DL20 Gen9, DL20 Gen9 Entry, DL20 Gen9 Performance, DL360 G5, DL360 G5 Base, DL360 G5 Entry, DL360 G5 High Efficiency, DL360 G5 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL360 Gen9 Base, DL360 Gen9 Entry, DL360 Gen9 High Performance, DL360 Gen9 Performance, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL365, DL365 Base, DL365 Entry, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL365 Performance, DL380 Gen9, DL380 Gen9 Base, DL380 Gen9 Entry, DL380 Gen9 High Performance, DL380 Gen9 Performance, DL580 G4 High Performance, DL60 Gen9, DL60 Gen9 Base, DL60 Gen9 Entry, DL80 Gen9, DL80 Gen9 Base, DL80 Gen9 Entry, e2000 G6, ML150 Gen9, ML150 Gen9 Base, ML150 Gen9 Entry, ML150 Gen9 Performance, ML350 G5, ML350 G5 1.5 TB Storage Server, ML350 G5 1.8TB SAS Storage Server, ML350 G5 3 TB Storage Server, ML350 G5 960 GB Storage Server, ML350 G5 Base, ML350 G5 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML350 Gen9, ML350 Gen9 Base, ML350 Gen9 Entry, ML350 Gen9 Performance , HPE Rack , HPE UPS R12000/3, R7000, R8000/3 , HPE 3PAR StoreServ 10400, StoreServ 10400 Controller Node, StoreServ 10800 Controller Node
