Hop on the call with instant ease, looking and sounding great. Just plug in this wide-view FHD 1080p all-in-one webcam and let it do the rest, so you can focus on what matters. It also features auto image and light correction, Works With Chromebook Certification, and a lens cover for privacy.
- HP 325 - webcam
- Webcam - pan
- Audio
- Yes: built-in microphone
- 7.2 cm x 5.36 cm x 5.32 cm
- 107 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Panning Range (degree)
- 360
- USB 2.0
- Cables Included
- 1 - USB cable - 1.5 m
- Privacy shutter, 66° field of view (wide), auto-light correction, Zoom compatible, Microsoft Teams compatible
- Works With Chromebook
- Webcam
- Audio Support
- Wired
- 7.2 cm
- 5.36 cm
- 5.32 cm
- 107 g
Camera
- Colour - pan
- Max Digital Video Resolution
- 1920 x 1080
- Video Capture
- 1920 x 1080 @ 30 fps
Image Sensor
- Total Pixels
- 1920 x 1080
Panning
- Range (degree)
- 360
- Computer Interface
- USB 2.0
- Included Accessories
- Clip mount
- Cables Included
- 1 x USB cable - 1.5 m
- OS Required
- Windows 10, Windows 11, Google Chrome OS, Apple MacOS
