HP 324pv Series 3 Pro 23.8" 1920x1080 5ms VGA HDMI LED Monitor
Quicklinx: J2NMWS00 Mfr#: 9U5C1AA#ABU
31 In Stock
£73.86 ex VAT
£88.63 inc VAT
Expand your view and boost productivity with an additional 23.8 inches of workspace from this FHD monitor. Work in comfort with a crisp, smooth screen and simple design, so you can get more done everyday.
  • Enhanced Contrast
    See even more of the nuanced differences of color, shadow, and highlights thanks to an enhanced 3000:1 contrast ratio.
  • Always-on, True Color, Low-Blue Light Filter
    HP Eye Ease, an always-on, hardware low-blue light filter, helps keep your eyes comfortable throughout the day by reducing blue light without the yellow color shift.
  • 100 Hz Refresh Rate
    Experience smooth scrolling, life-like video and clear detail with a 100 Hz refresh rate that provides fluid movement from frame to frame.
  • Adjustable Tilt
    The tilt-adjustable slim stand helps you find the right angle so you can maximize productivity and work comfortably.
  • Plenty of Ports
    This monitor is ready to connect for sharp FHD visuals with 1 x VGA and 1 x HDMI 1.4 port.
  • 3-Sided Micro-Edge Bezel
    See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and virtually seamless dual-monitor setups.
HP 324pv - Series 3 Pro - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
53.89 cm x 18.05 cm x 39.79 cm
3.56 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
CSA, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, TUV Bauart, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, ICE, UAE, Vietnam MEPS, TUV low blue light, TUV flicker free, Works With Chromebook (WWCB) certified, UAE RoHS
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
3000:1
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 115 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
3-sided micro-edge, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease
53.89 cm x 18.05 cm x 39.79 cm - with stand
3.56 kg
HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
14 kWh/1000h
Power Consumption (Typical)
20 Watt
Power Consumption (Max)
30 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.79 cm - weight: 3.56 kg , Without stand - width: 53.89 cm - depth: 5.14 cm - height: 32.36 cm
Shipping Width
59.5 cm
Shipping Depth
12.4 cm
Shipping Height
39.1 cm
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
Brand: HP
