Expand your view in comfort with a spacious, thoughtfully designed 23.8 inches of workspace. Boasting a crisp, smooth screen and a simple yet functional design, this HP Series 3 Pro 23.8" FHD monitor lets you work better all day.
- HP 324ph - Series 3 Pro - LED monitor - Full HD (1080p) - 24" - Smart Buy
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2239418
- Energy Class
- Class D
- Power Consumption (On mode)
- 14 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 53.89 cm x 19.63 cm x 46.92 cm
- 4.71 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- VCCI, C-Tick, BSMI, NOM, CCC, IC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, PSE Mark, cTUVus, TUV Bauart, E-Standby, CEC, KC, CEL, EAC, ISC, RCM, CEL Grade 2, SEPA, BIS, low halogen, Energy-using Products (EuP) Lot 5, NRCS, Mexico Energy label, Energy-using Products (EuP) Lot 26, CB 60950, UAE, CB 62368-1, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TGM, Australia MEPS, Works With Chromebook (WWCB) certified, Argentina S-Mark, Ukraine CoC, Ukraine DOC
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 115 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 3-sided borderless
- Black
- 53.89 cm x 19.63 cm x 46.92 cm - with stand
- 4.71 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- HDMI (HDCP) , VGA , DisplayPort 1.2 (HDCP)
Mechanical
- Height, tilt
- Tilt Angle
- -5/+23
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x HDMI cable
- Backlight Life
- 30,000 hours
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14 W
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 23 Watt
- Power Consumption (Max)
- 35 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Client Management Script Library, HP Display Center
- Dimensions & Weight Details
- With stand - width: 53.89 cm - depth: 19.63 cm - height: 46.92 cm - weight: 4.71 kg , Without stand - width: 53.89 cm - depth: 4.94 cm - height: 32.42 cm - weight: 3.4 kg
- Shipping Width
- 59.5 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 39.1 cm
- Shipping Weight
- 6.74 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
