Print crisp text and vivid colour photos for home and small business with HP Original Ink cartridges. Choose between cartridge sizes to match your printing volume and budget.
Know when you are running low on ink
Easily complete your projects. Low-ink alerts can help ensure you don't run out of ink at the wrong time. -
Recyclable and recycled content
HP ink cartridges have been engineered to use recycled plastic and help meet HP's demanding standards. -
HP Smart app
Save time with HP Smart app. Know when you are running low and easily order ink from your smartphone. -
Designed to deliver
Help ensure the crisp, vivid prints for home, school, and work with cartridges built and tested with your HP printer and designed for ease of use.
- HP 305XL - High Yield - colour (cyan, magenta, yellow) - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Colour (cyan, magenta, yellow)
- Capacity
- 5 ml
- Cartridge Yield
- High Yield
- Yield
- Up to 200 pages ISO/IEC 24711
- Compatible with
- Deskjet 1200, 23XX, 27XX, 28XX, 41XX, 42XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
- Shipping Width
- 11.3 cm
- Shipping Depth
- 3.7 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 50 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 1-pack
- Capacity
- 5 ml
- Cartridge Yield
- High Yield
- Yield
- Compatible with
- HP Deskjet 1200c, 1200c/ps, 1200ps, 2320, 2330, 2331, 2332, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2725, 2729, 2732, 2734e, 2742, 2742e, 2752, 2752e, 2755, 2755e, 2776, 2810e, 2820e, 2821e, 2822e, 2823e, 2855e, 4110e, 4120e, 4121e, 4130e, 4132e, 4152e, 4155e, 4158e, 4175e, 4210e, 4220e, 4222e, 4230e, 4255e , HP DeskJet Plus 4110, 4120, 4121, 4122, 4122e, 4123, 4130, 4140, 4152, 4155, 4155e, 4158 , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6432e, 6452e, 6455e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
