Brand
HP 305 Colour (Cyan, Magenta, Yellow) Original Ink Cartridge
Quicklinx: G403WS00 Mfr#: 3YM60AE#UUS
More than 50 in stock
£8.08 ex VAT
£9.69 inc VAT
Print crisp text and vivid colour photos for home and small business with HP Original Ink cartridges. Choose between cartridge sizes to match your printing volume and budget.
  • Designed to work the first time, every time
    Be assured that HP Original Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Get the most from your ink
    Get the most from your HP printer – and your ink. Print the high-quality documents and store-quality photos you need, using HP Original Ink Cartridges. Choose between cartridge sizes to match your printing volume and budget.
  • Crisp, sharp text and vivid colours
    Make a good impression with HP Original Ink Cartridges – designed to deliver vivid colour and crisp, sharp text.
HP 305 - colour (cyan, magenta, yellow) - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Colour (cyan, magenta, yellow)
4.48 ml
Yield
Up to 100 pages ISO/IEC 24711
Compatible with
Deskjet 1255, 23XX, 27XX, 41XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
Shipping Width
11.3 cm
Shipping Depth
3.7 cm
Shipping Height
11.5 cm
Shipping Weight
50 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Included Qty
1-pack
4.48 ml
Yield
Compatible with
HP Deskjet 1255, 2320, 2330, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2732, 2742, 2742e, 2752, 2755, 2755e, 4110e, 4120e, 4121e, 4130e, 4152e, 4158e , HP DeskJet Plus 4120, 4122, 4122e, 4130, 4140, 4152, 4155, 4155e , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6452e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
Brand: HP
Stock Status: In stock
