Print crisp text and vivid colour photos for home and small business with HP Original Ink cartridges. Choose between cartridge sizes to match your printing volume and budget.
Designed to work the first time, every time
Be assured that HP Original Cartridges will consistently deliver quality results and premium performance. -
Quality prints you can take pride in
Experience premium print quality with HP Original Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact. -
The environmental choice
Print with confidence – HP Original Cartridges designed with the planet in mind for easy recycling and less waste. -
Better together. Better results
HP Original Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance. -
Get the most from your ink
Get the most from your HP printer – and your ink. Print the high-quality documents and store-quality photos you need, using HP Original Ink Cartridges. Choose between cartridge sizes to match your printing volume and budget. -
Crisp, sharp text
Make a good impression with Original HP ink cartridges – designed to deliver crisp, sharp text.
- HP 305 - black - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Black (pigmented)
- Capacity
- 3.55 ml
- Yield
- Up to 120 pages ISO/IEC 24711
- Compatible with
- Deskjet 1255, 23XX, 27XX, 41XX; DeskJet Plus 41XX; ENVY 60XX, 64XX; ENVY Pro 64XX
- Shipping Width
- 11.3 cm
- Shipping Depth
- 3.7 cm
- Shipping Height
- 11.5 cm
- Shipping Weight
- 50 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Black (pigmented)
- Included Qty
- 1-pack
- Capacity
- 3.55 ml
- Yield
- Compatible with
- HP Deskjet 1255, 2320, 2330, 2710, 2710e, 2720, 2720e, 2721, 2721e, 2722, 2722e, 2723, 2723e, 2724, 2732, 2742, 2742e, 2752, 2755, 2755e, 4110e, 4120e, 4121e, 4130e, 4152e, 4158e , HP DeskJet Plus 4120, 4122, 4122e, 4130, 4140, 4152, 4155, 4155e , HP ENVY 6010, 6010e, 6020, 6020e, 6022, 6022e, 6030, 6030e, 6032, 6032e, 6034, 6034e, 6052, 6052e, 6055, 6055e, 6058, 6075, 6420e, 6430e, 6452e, 6458e , HP ENVY Pro 6420, 6422, 6430, 6430e, 6432, 6432e, 6452, 6454, 6455, 6455e, 6458, 6475
