HP 290 G2 MT Core i3-8100 4GB 500GB HDD Windows 10 Pro
Quicklinx: DV9HWS00 Mfr#: 3VA91EA#ABU
  • Core i3
Take on your everyday work at an affordable price with the HP 290 MT. Get the reliable computing power you need while minimizing the total cost of ownership-now that's a smart investment.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Hassle-free connectivity
    Get fast and easy connections with optional Gigabit LAN and WLAN featuring 802.11ac protocol and Bluetooth 4.2 connectivity.
  • Peripheral support
    Support two independent displays with VGA and HDMI connectivity and plug in up to 8 compatible USB devices and utilize an optional serial port.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Clean software image
    With the clean, professional software image on the HP 290 MT, you will be productive in no time!
HP 290 G2 - micro tower - Core i3 8100 3.6 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower
Intel Core i3 (8th Gen) 8100 / 3.6 GHz (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
Intel UHD Graphics 630
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
17 cm x 33.8 cm x 27.75 cm
5.4 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Chipset Type
Intel H370
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared
Slots
1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe , 1 (total) / 1 (free) x M.2 Card - 2230/2280
4 x USB 2.0 , 1 x headphones/microphone (1 in front) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x HDMI , 1 x microphone , 1 x serial
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Power Provided
180 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
17 cm
33.8 cm
27.75 cm
5.4 kg
Shipping Width
29.1 cm
Shipping Depth
39 cm
Shipping Height
49.9 cm
Shipping Weight
8 kg
10 - 90%
