HP 290 G1 i3-7100 4GB 256GB Win10 Pro
Quicklinx: D610WS00 Mfr#: 1QN78EA#ABU
  • Core i3
Take on your everyday work at an affordable price with the HP 290. Get the computing power you need and the total cost of ownership - now that's a smart investment.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Port support
    Make connections to peripherals with eight USB ports on the HP 290 G1 MT with two front USB 3.0 ports, two rear USB 3.0, and four rear USB 2.0 ports. Support two independent displays with VGA and HDMI connectivity.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Clean software image
    With the clean, professional software image on the HP 290 G1 MT, you will be productive in no time!
HP 290 G1 - micro tower - Core i3 7100 3.9 GHz - 4 GB - SSD 256 GB
Personal computer - micro tower
Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Smart Cache
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, Windows Defender, HP Velocity, HP JumpStart, HP JetAdvantage
17 cm x 27.4 cm x 33.8 cm
5.45 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Ethernet Controller
Realtek RTL8111G-CG
Wake on LAN (WoL)
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x M.2 Card , 1 (total) / 1 (free) x PCIe 2.0 x1
4 x USB 2.0 , 1 x headphones/microphone (1 in front) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x HDMI
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
17 cm
27.4 cm
33.8 cm
5.45 kg
10 - 90%
