Optimize your resources with the HP 285 MT equipped with powerful processors, security features, and essential tools for business. This easy to set up PC has a scalable and functional design that can grow with your business.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Help secure critical data
The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials. -
Six USB ports
Make connections to peripherals with six USB ports on the HP 285 MT. Two front USB 2.0 and two rear USB 2.0 ports are ready to connect to compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone. -
PC management made more manageable
Spend less time and get right to the updates you need with HP Support Assistant. -
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
- HP 285 G2 - micro tower - A8 PRO-7600B 3.1 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - micro tower
- Localisation
- Processor
- AMD A8 PRO-7600B / 3.1 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Socket
- Socket FM2+
- Cache Memory
- 4 MB L2 Cache
- Cache Per Processor
- 4 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- AMD Radeon R7
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition
- 17 cm x 35.5 cm x 35.88 cm
- 6.11 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A8 PRO-7600B
- Clock Speed
- 3.1 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- Socket FM2+
- Chipset Type
- AMD A78 FCH
Cache Memory
- Installed Size
- L2 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- AMD Radeon R7
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP USB Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111G
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
- Slots
- 2 (total) / 1 (free) x DIMM 240-pin
- 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x DisplayPort , 1 x VGA , 1 x LAN (Gigabit Ethernet) , 2 x PS/2 keyboard / mouse , 1 x serial
- Theft/Intrusion Protection
- Power supply
- Power Provided
- 180 Watt
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 17 cm
- 35.5 cm
- 35.88 cm
- 6.11 kg
