HP 280 G2 SFF Intel Pentium G4400 4GB 500GB Windows 10 Professional
Quicklinx: CF3DWS00 Mfr#: Y5P88EA#ABU
  • Pentium
Take on your everyday work at an affordable price with the HP 280 SFF. Get the computing power you need while minimizing the PC footprint and the total cost of ownership-now that's a smart investment.
Performance
New Intel and Microsoft technology: Intel H110 Chipset with 6th generation processors and IntelĀ® HD Graphics 530 or 510 (varies by processor).
Up to 32GB DDR4 memory (2 slots)
128 GB SSD drives.
Provides fast boot time with the high performing storage option from HP
Keep Up with the Work Space
Offers VGA and HDMI port, Giga-bit LAN, 8 USB ports (including 2 USB 3.0 in front), integrated SD card reader, and optional Intel wireless LAN
Front combo audio jack works perfectly with your cellphone headset without a converter cable
7.8L chassis that works well in both horizontal and vertical orientation
Device Security and Manageability
Management utility "HP Touchpoint Manager" by HP, developed for small and medium business
Enhanced Collaboration
HP Conferencing Keyboard and headset for enhanced video conferencing
Latest Technology
Refresh with IntelĀ® 6th Gen processors and H110 chipset.
Microsoft Windows 10
Performance Boost
With DDR4 memory and optional SSD up to 128GB
Keep Up With Your Need
Up to 8 USB ports (including 2 USB 3.0 in front) and embedded SD reader for your media card. HDMI port gives you compatibility with the monitors Combo audio jack works well with your headset worry-free.
Easy to Deploy
Reliable thermal with no vents on the side or top, for your easy deployment together with a monitor
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Eight USB ports
    Connect peripherals and devices via an HDMI port, a VGA port, two front USB, and six rear USB ports.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Clean software image
  • Accidents happen. HP can help
    Optional HP Care Packs with Accidental Damage Protection helps you avoid out-of-pocket repair or replacement costs and delivers service right to your door.
HP 280 G2 - SFF - Pentium G4400 3.3 GHz - 4 GB - HDD 500 GB - UK
Personal computer - small form factor
Intel Pentium G4400 / 3.3 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
3 in 1
Graphics Controller
Intel HD Graphics 510
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
CyberLink Power2Go, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink Power Media Player
29 cm x 27 cm x 10 cm
3.66 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site , Technical support - phone consulting - 1 year
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Intel Pentium G4400
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
3 in 1 card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Keyboard
Keyboard
USB
Localization & Layout
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line ¦ 1 (total) / 0 (free) x internal 3.5"
Slots
2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
2 x USB 3.0 (2 in front) , 6 x USB 2.0 , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, FCC, RoHS, WEEE, CECP, CEL, SEPA
Power supply
Power Provided
180 Watt
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.1
Limited warranty - parts and labour - 1 year - on-site ¦ Technical support - phone consulting - 1 year
29 cm
27 cm
10 cm
3.66 kg
10 °C
35 °C
10 - 90% (non-condensing)
