HP 280 G2 MT Intel Core i5-6599 4GB 500GB HDD Windows 7 Professional
Quicklinx: C7HHWS00 Mfr#: V7Q83EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
Take on your work with the HP 280 MT desktop PC. Get the computing power you need for your business while minimizing the total cost of ownership-now that's a smart investment.
Dependable and ready for work
The HP 280 MT delivers reliable performance for your business with the tools you need for work. Enhance your meeting experience with the optional HP Conferencing Keyboard and HP Business Headset for collaboration.
Powered up processing
Cruise through tasks easily and efficiently with 6th Generation Intel® Core™ i3/i5 processors and up to 32 GB of powerful DDR4 memory for demanding applications.
Progressive style
Enjoy the full desktop experience on the scalable HP 280 MT with a functional design that compliments your workspace and is easy to set up and use.
Expansion options
PCIe x1 and PCIe x16 slots along with VGA and DVI-D ports, and an SSD drive option on the HP 280 Microtower help ensure broad compatibility with existing technology investments and future upgrades.
  • Let nothing stand in your way
    Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business.
  • Help secure critical data
    The embedded Trusted Platform Module 1.2 (TPM) is field upgradeable to TPM 2.0 through a firmware upgrade which provides hardware-based encryption keys to help secure your data, e-mail, and user credentials.
  • Eight USB ports
    Make connections to peripherals with eight USB ports on the HP 280 MT. Two front and four rear USB 2.0 ports are ready to connect to USB compatible peripherals, while two rear USB 3.0 ports are ready to charge your tablet or phone.
  • PC management made more manageable
    Quickly get to the updates you need with HP Support Assistant.
  • Simple wireless printing
    Make better use of your workspace. HP ePrint makes wireless printing simple, no need for drivers.
  • Valuable support at your service
    Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices, and operating systems.
HP 280 G2 - micro tower - Core i5 6500 3.2 GHz - 4 GB - HDD 500 GB
Personal computer - micro tower
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
GigE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro) + Windows 10 Pro Licence
Software Included
CyberLink Power2Go, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP BIOS Configuration Utility (free download)
17 cm x 35.5 cm x 35.88 cm
6.11 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111G-CG
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
6 x USB 2.0 (2 front, 4 rear) , 1 x headphones/microphone (1 in front) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x VGA , 1 x DVI-D
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, FCC, WEEE, CECP, CEL, SEPA
Power supply
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
Software
17 cm
35.5 cm
35.88 cm
6.11 kg
10 °C
35 °C
10 - 90% (non-condensing)
