HP 280 G1 MT Intel Core i5-4590S 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BGFVWS00 Mfr#: M3X31EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
Take on your everyday work at an affordable price with the HP 280 G1 desktop PC. Get the computing power you need while minimizing the total cost of ownership-now that's a smart investment.
  • Windows 8.1
    Start up in an instant, quickly switch between applications, and manage files with the quick and fluid Windows 8.1.
  • Powered up processing
    Cruise through tasks easily and efficiently with the latest processor technology. The 4th Generation Intel CoreTM i3/i5 processor boasts a powerful H81 chipset, processor support and robust 16GB of memory.
  • Help secure critical data
    The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials.
  • Eight USB ports
    Make connections to peripherals with eight USB ports on the HP 280 G1 MT. Two front USB 2.0 ports are ready to charge your tablet or phone, while six rear (two USB 3.0 and four USB 2.0) USB ports are ready to connect to USB compatible peripherals.
  • PC management made more manageable
    Spend less time and get right to the updates you need with HP Support Assistant.
  • Simple wireless printing
    Make better use of your workspace. HP ePrint makes wireless printing simple, no need for drivers.
HP 280 G1 - micro tower Core i5 4590S 3 GHz - 4 GB - HDD 500 GB - UK
Personal computer - micro tower
Intel Core i5 (4th Gen) 4590S / 3 GHz (up to 3.7 GHz, (Quad-Core)
Processor Socket
LGA1150 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 4600
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
16.5 cm x 35.5 cm x 35.88 cm
7.05 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Micro tower
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3 GHz
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Audio Output
Sound Output Mode
Stereo
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
Slots
2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1
6 x USB 2.0 (2 front, 4 rear) , 2 x USB 3.0 , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
UL, FCC, WEEE, CECP, CEL level 1, SEPA
Power supply
Power Provided
180 Watt
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
16.5 cm
35.5 cm
35.88 cm
7.05 kg
10 °C
35 °C
10 - 90% (non-condensing)
