Take on your everyday work at an affordable price with the HP 280 G1 desktop PC. Get the computing power you need while minimizing the total cost of ownership-now that's a smart investment.
Windows 8.1
Start up in an instant, quickly switch between applications, and manage files with the quick and fluid Windows 8.1. -
Powered up processing
Cruise through tasks easily and efficiently with the latest processor technology. The 4th Generation Intel CoreTM i3/i5 processor boasts a powerful H81 chipset, processor support and robust 16GB of memory. -
Help secure critical data
The embedded Trusted Platform Module 1.2 (TPM) provides hardware-based encryption keys to help secure your data, e-mail, and user credentials. -
Eight USB ports
Make connections to peripherals with eight USB ports on the HP 280 G1 MT. Two front USB 2.0 ports are ready to charge your tablet or phone, while six rear (two USB 3.0 and four USB 2.0) USB ports are ready to connect to USB compatible peripherals. -
PC management made more manageable
Spend less time and get right to the updates you need with HP Support Assistant. -
Simple wireless printing
Make better use of your workspace. HP ePrint makes wireless printing simple, no need for drivers.
- HP 280 G1 - micro tower Pentium G3250 3.2 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - micro tower
- Localisation
- Processor
- Intel Pentium G3250 / 3.2 GHz (Dual-Core)
- Processor Socket
- LGA1150 Socket
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, Microsoft Security Essentials, HP Support Assistant, HP ePrint
- 16.5 cm x 35.5 cm x 35.88 cm
- 7.05 kg
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, DVI
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 0 (free) x CPU , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1
- 6 x USB 2.0 (2 front, 4 rear) , 2 x USB 3.0 , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x VGA , 1 x DVI-D
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- UL, FCC, WEEE, CECP, CEL level 1, SEPA
- Power supply
- Power Provided
- 180 Watt
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
- 16.5 cm
- 35.5 cm
- 35.88 cm
- 7.05 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
