Manage your print environment – and budget – with this advanced, network-ready MFP and get up to 50% lower cost per page than lasers. Enjoy easy integration into your office workflow with efficient management and security controls.
Save time, streamline workflows and simplify office tasks
Access print tools and useful business apps via the intuitive control panel and large colour touchscreen.Handle large jobs with automatic two-sided printing, copying and scanning – load up to 500 sheets at once with the optional paper tray.Print up to 2,300 black pages – or up to 1,500 colour pages – from a single high capacity Original HP cartridge.Choose HP for reliable workgroup printing – designed for volumes of up to 1,500 pages a month. -
Conserve resources without sacrificing performance
Use up to 50% less energy than colour lasers – set your printer for savings with Schedule On and Schedule Off.Save up to 50% on paper with automatic two-sided printing.Use up to 50% less supplies and packaging by weight compared with colour laser.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro 276dw MFP - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 impressions
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 12 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 15 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 4800 x 4800 dpi
- Original Size
- 216 x 356 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, greeting cards, photo paper, thick paper, card stock, glossy photo paper, matte photo paper, tri-fold paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, scan to folder, save to network folder
- Power
- AC 110/230 V (50/60Hz)
- 49.4 cm x 46 cm x 31.5 cm
- 12.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 impressions
- 250 - 1500 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF
- First Print Out Time B/W
- 13 sec
- First Print Out Time Colour
- 14 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- 48 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- 216 x 356 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- 250 sheets
- 500 sheets
- 150 sheets
- Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 150 sheets
- Speed Details
- Printing: up to 25 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Printing: up to 20 ppm - B/W (ISO) , Printing: up to 15 ppm - colour (ISO) , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 12 ppm - colour (ISO)
- 1 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, Apple Bonjour, LEAP, TLS, 802.1x
- Operating System Support
- Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities, HP ePrint Wireless Direct
- Voltage Required
- 35.09 Watt
- Power Consumption Standby
- 7.11 Watt
- Power Consumption Sleep
- 1.63 Watt
- ETSI, GOST, RoHS, REACH, LVD
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- 49.4 cm
- 46 cm
- 31.5 cm
- 12.7 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 38 cm
- Shipping Height
- 52 cm
- Shipping Weight
- 18.2 kg
- Sound Emission
- 62 dBA (operating)
- 15 °C
- 30 °C
- 15 - 80%
Ink (2)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.04 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.52 |
Other bundles (1)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
