HP 260 G1 DM Intel Core i3-4030U 4GB 500GB Windows 7 Professional 64-bit
CLEARENCE WAS £297 NOW £280!
Quicklinx: BC69WS00 Mfr#: L3E25EA#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
The fully functional HP 260 Desktop Mini PC delivers the benefit of space saving design that can grow with your business and is equipped with the essential tools you need at an affordable price.
  • Power-saving processors
    Do your part to reduce energy use and costs with processors that help consume less than half the energy of those in other mini PCs.
  • Fearless flexibility
    Take advantage of expandable and compatible HP mini accessories. Expand storage options, add legacy ports with expansion modules, help secure your device with security mounts, or take back your desk space with stands and work centers.
  • Easy on
    Help keep your investment safe and conveniently power up your desktop mini directly from the keyboard so you don't have to open enclosures or strain for the power button when it's out of reach.
  • Connect to more capabilities
    Do more on dual displays with DisplayPort 1.2 and full HD VGA ports, plus use 6 USB ports to plug in all the peripherals you need.
  • Work with your preferred Windows
    Choose the operating system that best fits your needs from a range of Windows options including Windows 8.1, Windows 7, and education editions.
  • Speedy storage
    Choose a standard hard drive or upgrade to a speedy and reliable solid state drive.
HP 260 G1 - mini desktop - Core i3 4030U 1.9 GHz - 4 GB - HDD 500 GB - UK
Personal computer - mini desktop
Intel Core i3 (4th Gen) 4030U / 1.9 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4400
Audio Output
Integrated
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Microsoft Internet Explorer, Cyberlink PowerDVD, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, HP Setup, Bingbar, HP Registration, HP PC Hardware Diagnostics UEFI, Getting Started guide with Windows 8, DTS Sound+, HP Touchpoint Manager
17.7 cm x 17.5 cm x 3.4 cm
700 g
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
1.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
Integrated
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Localization & Layout
Mouse
USB
Integrated
Ethernet Controller
Realtek RTL8151GH-CG
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Half Mini Card , 1 (total) / 0 (free) x CPU
4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 (2 rear) , 1 x audio line-in/microphone (1 in front) , 1 x audio line-out/headphones (1 in front) , 1 x VGA (1 rear) , 1 x DisplayPort (1 rear) , 1 x LAN (Gigabit Ethernet) (1 rear) , 1 x audio line-out (1 rear)
Vertical stand
Theft/Intrusion Protection
UL, cUL, FCC, RoHS2
Power adapter
Power Provided
65 Watt
Efficiency
89%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Software
17.7 cm
17.5 cm
3.4 cm
700 g
5 °C
35 °C
15 - 80%
