HP 255 G7 AMD Ryzen 5 2500U 8GB 256GB SSD 15.6" Windows 10 Home 64-bit
Quicklinx: FBTXWS00 Mfr#: 7DC73EA#ABU
Display Size: 15.6in
Processor Model: 2500U
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • IEEE 802.11n
More than 50 in stock
£316.66 ex VAT
£379.99 inc VAT
Get connected with the value-priced HP 255 Notebook PC with the latest technology and a durable chassis that helps protect the notebook. Complete business tasks with an AMD Ryzen processor and essential collaboration tools.
  • Powered for business
    Confidently complete projects with the latest technology including a powerful AMD Ryzen processor, fast memory, and plenty of storage.
  • Durable mobile design
    Rest assured that the HP 255 can keep up with mobile workstyles with a thinner and lighter design. The durable chassis protects the notebook, so it looks as professional as you do.
  • Well-connected
    This notebook is ready to connect to all your peripherals and is designed to fit the needs of business with an RJ-45 port and HDMI port.
HP 255 G7 - 15.6" - Ryzen 5 2500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit - English
AMD Ryzen 5 2500U / 2 GHz (3.6 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD TLC
Optical Drive
DVD-Writer
Display
15.6" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega
Keyboard
Numeric Keypad
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Asteroid silver
37.6 cm x 24.6 cm x 2.25 cm
1.78 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Home 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Platform Technology
Intel vPro Technology
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) SATA 6Gb/s - triple-level cell (TLC)
Optical Drive
DVD-Writer
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Full HD standard-viewing angle (SVA) eDP anti-glare, 67% sRGB colour gamut
Audio & Video
Graphics Processor
AMD Radeon Vega
Sound
Stereo speakers
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Multi-touch touchpad, touchpad with gesture support
Communications
Wireless
Network Interface
Gigabit Ethernet
Miracast, single stream (1x1)
IEEE 802.11, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
41 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
2 x USB 3.1 Gen 1 , USB 2.0 , HDMI , Headphone/microphone combo jack , LAN
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Asteroid silver
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
UL, VCCI, GOST, SABS, CCC, MIC, FCC, KCC, ICES
Localization
1.78 kg
ENERGY STAR Certified
Software applications
HP 255 G7 AMD Ryzen 5 2500U 8GB 256GB SSD 15.6 Bundle deal on HP 255 G7 AMD Ryzen 5 2500U 8GB 256GB SSD 15.6" Windows 10 Home 64-bit
£499.67
saving £8.33
£415.83
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FBTX 041232
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £243.22
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Optical Storage: DVD-Writer
Graphics: AMD Radeon Vega
Hard Drive Type: SSD
Brand: HP
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
