HP 230W Slim AC Adapter
Quicklinx: 9RCJWS00 Mfr#: H1D36AA#ABU
HP includes a high quality AC adapter with each HP Business Notebook, HP Slate, HP Mini and HP Docking Station. Designed and tested to ensure optimum power support, the adapter also charges the notebook's internal battery simultaneously when connected. The.
HP Slim - power adapter - 230 Watt
Power adapter - external
0.81 kg
English / United Kingdom
Input Voltage
AC 90-265 V
Output Voltage
19.5 V
Power Capacity
230 Watt
20 cm x 10 cm x 2.6 cm
1-year warranty
EliteBook 2170p, 2570p, 8570w Mobile Workstation, 8770w Mobile Workstation; ProBook 4340s, 4540s, 4545s, 4740s; ZBook 15 Mobile Workstation, 17 Mobile Workstation
Input Voltage
AC 90-265 V
Frequency Required
47 - 63 Hz
Output Voltage
19.5 V
Power Capacity
230 Watt
Power cable - external
Over voltage protection, automatic shut down
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, PSB, SII, PSE Mark, S Mark, KC
Limited warranty - replacement - 1 year
5 °C
35 °C
10 - 95%
20 cm
10 cm
2.6 cm
0.81 kg
HP EliteBook 2170p, 2570p, 8570w Mobile Workstation, 8770w Mobile Workstation , HP ProBook 4340s, 4540s, 4545s, 4740s , HP ZBook 15 Mobile Workstation, 17 Mobile Workstation
