HP includes a high quality AC adapter with each HP Business Notebook, HP Slate, HP Mini and HP Docking Station. Designed and tested to ensure optimum power support, the adapter also charges the notebook's internal battery simultaneously when connected. The.
- HP Slim - power adapter - 230 Watt
- Power adapter - external
- 0.81 kg
- Localisation
- English / United Kingdom
- Input Voltage
- AC 90-265 V
- Output Voltage
- 19.5 V
- Power Capacity
- 230 Watt
- 20 cm x 10 cm x 2.6 cm
- 1-year warranty
- Designed For
- EliteBook 2170p, 2570p, 8570w Mobile Workstation, 8770w Mobile Workstation; ProBook 4340s, 4540s, 4545s, 4740s; ZBook 15 Mobile Workstation, 17 Mobile Workstation
- Localisation
- Input Voltage
- AC 90-265 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- 19.5 V
- Power Capacity
- 230 Watt
- Cables Included
- Power cable - external
- Over voltage protection, automatic shut down
- CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, PSB, SII, PSE Mark, S Mark, KC
- Limited warranty - replacement - 1 year
- 5 °C
- 35 °C
- 10 - 95%
- 20 cm
- 10 cm
- 2.6 cm
- 0.81 kg
- Designed For
- HP EliteBook 2170p, 2570p, 8570w Mobile Workstation, 8770w Mobile Workstation , HP ProBook 4340s, 4540s, 4545s, 4740s , HP ZBook 15 Mobile Workstation, 17 Mobile Workstation
