HP 225 Keyboard and Mouse Set - UK Input Device
Quicklinx: HBSLWS00 Mfr#: 286J4AA#ABU
Wired / Wireless: Wired
Compatibility: PC
£29.25 ex VAT
£35.10 inc VAT
Think how much you use your mouse and keyboard. That's why we've taken the time to design products that are comfortable to use so you can work productively every day - and all day if necessary.
  • Designed for comfort
    This mouse and keyboard are one comfortable combo. The mouse has perfectly positioned left and right buttons and a scroll wheel. Plus, with 0-6-degree adjustable feet, you'll be able to type comfortably on a three-zone, full sized keyboard.
  • Plug and play connectivity
    Connecting some peripheral devices can be a complex and time-consuming task. Who needs that? With easy plug and play USB connectivity, you can get your mouse and keyboard connected quickly so you can get on with your work day.
  • Responsibly made
    You should feel good about the products you buy and use. Rest assured, this wired keyboard is responsibly made with over 50% of the plastics comprised of recycled materials, and the printed circuit boards on the keyboard and mouse are low halogen.
  • Easy cleaning
    Use your mouse and keyboard every day and they will accumulate dirt and grime. Over time, this can affect how they perform. Because they were specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse and keyboard combo that's a snap to keep clean.
HP 225 - keyboard and mouse set - UK Input Device
Keyboard and mouse set
USB
Wired
Localization and Layout
Numeric Keypad
Pointing Device
Mouse - wired
Buttons Qty
3
1-year warranty
HP 245 G9 Notebook, 295 G8, Z1 G8; Chromebook x360 11MK G3 Education Edition; EliteOne 800 G8; Laptop 15s-eq3029nl; ProDesk 405 G8
USB
Dimensions (WxDxH) / Weight
Keyboard: 43.6 cm x 13.8 cm x 2.03 cm , Mouse: 11.2 cm x 6.3 cm x 3.6 cm
Region
United Kingdom
Numeric keypad
Pointing Device
Mouse - wired
Buttons Qty
3
Cable Length
1.8 m
Plug and Play, IEEE 1680.1-2018
Limited warranty - 1 year
HP 245 G9 Notebook, 295 G8, Z1 G8 , HP Chromebook x360 11MK G3 Education Edition , HP EliteOne 800 G8 , HP Laptop 15s-eq3029nl , HP ProDesk 405 G8
Compatibility: PC
Brand: HP
Stock Status: While stocks last
Stock Status: Clearance
