Think how much you use your mouse and keyboard. That's why we've taken the time to design products that are comfortable to use so you can work productively every day - and all day if necessary.
Designed for comfort
This mouse and keyboard are one comfortable combo. The mouse has perfectly positioned left and right buttons and a scroll wheel. Plus, with 0-6-degree adjustable feet, you'll be able to type comfortably on a three-zone, full sized keyboard. -
Plug and play connectivity
Connecting some peripheral devices can be a complex and time-consuming task. Who needs that? With easy plug and play USB connectivity, you can get your mouse and keyboard connected quickly so you can get on with your work day. -
Responsibly made
You should feel good about the products you buy and use. Rest assured, this wired keyboard is responsibly made with over 50% of the plastics comprised of recycled materials, and the printed circuit boards on the keyboard and mouse are low halogen. -
Easy cleaning
Use your mouse and keyboard every day and they will accumulate dirt and grime. Over time, this can affect how they perform. Because they were specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse and keyboard combo that's a snap to keep clean.
- HP 225 - keyboard and mouse set - UK Input Device
- Keyboard and mouse set
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Numeric Keypad
- Pointing Device
- Mouse - wired
- Buttons Qty
- 3
- 1-year warranty
- Designed For
- HP 245 G9, 295 G8, 34, 470 G8, Z1 G8; Chromebook 14 G7; Chromebook x360; EliteBook 645 G9, 840; EliteOne 800 G8; Laptop 15s-eq3029nl; Pro Mobile Thin Client mt440 G3; Pro x360; ProBook 445 G8, 455 G8, 455 G9, 635; ProDesk 405 G8; ZBook Studio G9
- Interface
- USB
- Dimensions (WxDxH) / Weight
- Keyboard: 43.6 cm x 13.8 cm x 2.03 cm , Mouse: 11.2 cm x 6.3 cm x 3.6 cm
- UK
- Region
- United Kingdom
- Numeric keypad
Pointing Device
- Mouse - wired
- Buttons Qty
- 3
- Cable Length
- 1.8 m
- Plug and Play, IEEE 1680.1-2018
- Limited warranty - 1 year
- Designed For
- HP 245 G9 Notebook, 295 G8, 34, 470 G8 Notebook, Z1 G8 , HP Chromebook 14 G7 , HP Chromebook x360 11MK G3 Education Edition , HP EliteBook 645 G9 Notebook, 840 Aero G8 Notebook , HP EliteOne 800 G8 , HP Laptop 15s-eq3029nl , HP Pro Mobile Thin Client mt440 G3 , HP Pro x360 Fortis 11 G9 Notebook , HP ProBook 445 G8 Notebook, 455 G8 Notebook, 455 G9 Notebook, 635 Aero G8 Notebook , HP ProDesk 405 G8 , HP ZBook Studio G9 Mobile Workstation
