HP 225 Keyboard and Mouse Set - UK Input Device
Quicklinx: HBSLWS00 Mfr#: 286J4AA#ABU
Wired / Wireless: Wired
Compatibility: PC
More than 50 In Stock
£15.58 ex VAT
£18.69 inc VAT
Think how much you use your mouse and keyboard. That's why we've taken the time to design products that are comfortable to use so you can work productively every day - and all day if necessary.
  • Designed for comfort
    This mouse and keyboard are one comfortable combo. The mouse has perfectly positioned left and right buttons and a scroll wheel. Plus, with 0-6-degree adjustable feet, you'll be able to type comfortably on a three-zone, full sized keyboard.
  • Plug and play connectivity
    Connecting some peripheral devices can be a complex and time-consuming task. Who needs that? With easy plug and play USB connectivity, you can get your mouse and keyboard connected quickly so you can get on with your work day.
  • Responsibly made
    You should feel good about the products you buy and use. Rest assured, this wired keyboard is responsibly made with over 50% of the plastics comprised of recycled materials, and the printed circuit boards on the keyboard and mouse are low halogen.
  • Easy cleaning
    Use your mouse and keyboard every day and they will accumulate dirt and grime. Over time, this can affect how they perform. Because they were specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse and keyboard combo that's a snap to keep clean.
HP 225 - keyboard and mouse set - UK Input Device
Keyboard and mouse set
USB
Wired
Localization and Layout
Numeric Keypad
Pointing Device
Mouse - wired
Buttons Qty
3
1-year warranty
HP 245 G9, 255 G9, 34, 470 G8, Z1 G9; Elite x360; EliteBook 1040 G9, 645 G9, 65X G9, 830 G9, 840, 845 G9, 860 G9; Laptop 15; Pro Mobile Thin Client mt440 G3; Pro x360; ProBook 445 G8, 445 G9, 455 G8, 455 G9, 635, Fortis 14 G9; ZBook Power G9, Studio G9; ZBook Firefly 16 G9; ZBook Fury 16 G9
USB
Dimensions (WxDxH) / Weight
Keyboard: 43.6 cm x 13.8 cm x 2.03 cm , Mouse: 11.2 cm x 6.3 cm x 3.6 cm
Region
United Kingdom
Numeric keypad
Pointing Device
Mouse - wired
Buttons Qty
3
Cable Length
1.8 m
Plug and Play, IEEE 1680.1-2018
Limited warranty - 1 year
HP 245 G9 Notebook, 255 G9 Notebook, 295 G8, 34, 470 G8 Notebook, Z1 G8, Z1 G9 , HP Chromebook 11MK G9 Education Edition, 14 G7 , HP Chromebook x360 11MK G3 Education Edition , HP Elite x360 1040 G9 Notebook , HP EliteBook 1040 G9 Notebook, 645 G9 Notebook, 650 G9 Notebook, 655 G9 Notebook, 830 G9 Notebook, 840 Aero G8 Notebook, 845 G9 Notebook, 860 G9 Notebook , HP EliteOne 800 G8 , HP Engage Flex Mini Retail System , HP Laptop 15s-eq3029nl , HP Pro Mobile Thin Client mt440 G3 , HP Pro x360 435 G9 Notebook, Fortis 11 G9 Notebook , HP ProBook 445 G8 Notebook, 445 G9 Notebook, 455 G8 Notebook, 455 G9 Notebook, 635 Aero G8 Notebook, Fortis 14 G9 Notebook , HP ProDesk 405 G8 , HP ZBook Power G9 Mobile Workstation, Studio G9 Mobile Workstation , HP ZBook Firefly 16 G9 Mobile Workstation , HP ZBook Fury 16 G9 Mobile Workstation
Compatibility: PC
Brand: HP
