The HP 2211x offers a perfect combination of screen performance, sleek design, and responsible features with a 54,6 cm (21.5") diagonal LED Backlit LCD panel that can help enhance your workday.
Enhance your experience
The stylish, ultra-slim HP 2211x looks great in your office environment without taking up valuable space. Adjustable tilt settings also enable clear views from many angles so you can be more comfortable and productive at work. -
Boost your performance
Get crisp, clear, views on a full HD screen with a 3M:1 dynamic contrast ratio, up to a 170° viewing angle, and fast 5ms response times . As well, DVD-D and VGA inputs enable advanced connectivity. -
Enjoy extra benefits
The HP 2211x, with LED backlighting, delivers benefits over CCFL that include: the elimination of mercury, the use of solid state components to enable a thin, robust product, and quick on/off switching times to help save energy. -
Reduce your impact
With the use of Mercury-free LEDs and arsenic-free display glass, along with an ENERGY STAR qualification and an EPEAT Silver registration, the HP 2211x can help reduce your environmental impact.
- HP 2211x - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 68%
- Input Connectors
- DVI, VGA
- Tilt
- 51.9 cm x 15.9 cm x 39.6 cm
- 3.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV, VCCI, C-Tick, BSMI, CB, CCC, FCC, ISO 9241-307, S Mark, E-Standby
- Display Type
- Diagonal Size
- 21.5"
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Gamut
- 68%
- Response Time
- 5 ms
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- 3.5 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- 30
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Power Supply
- External
- Power Consumption (Typical)
- 29 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
Sustainability Information
- ENERGY STAR Certified
