This high-quality and affordable keyboard features a standard layout and a whole host of user-friendly functions.
- HPE Standard - keyboard - silver, carbonite Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Silver, carbonite
- 45.8 cm x 16.3 cm x 2.5 cm
- 0.9 kg
- 1-year warranty
- Keyboard
- Interface
- USB
- Region
- Kazakhstan
- Keyboard Technology
- Membrane
- 45.8 cm
- 16.3 cm
- 2.5 cm
- 0.9 kg
- Connections
- 1 x USB - 4 pin USB Type A
- Silver, carbonite
- Cables Included
- 1 x USB cable - 1.8 m
- FCC Class B certified, CSA, UL, TUV, ANSI-HFS-100, TUV GS, VCCI, ISO 9241-4, C-Tick, BSMI, PC 99, MIC
- OS Required
- Microsoft Windows 2000 / XP
- Limited warranty - 1 year
- 10 °C
- 50 °C
- 10 - 90%
- Sound Emission
- 43 dBA
