Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements. -
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs. -
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your PC.
- HP - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
- Product Type
- Memory module
- Capacity
- 16 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 2666 MHz (PC4-21300)
- Unbuffered
- Voltage
- 1.2 V
- OEM Manufacturer Equivalent Part Number
- HP 938168-001, HP 3TK84AT
- Manufacturer Selling Program
- HP Smart Buy
- Designed For
- Elite Slice G2 (SO-DIMM); EliteDesk 705 G4 (SO-DIMM), 705 G5 (SO-DIMM), 800 G4 (SO-DIMM), 800 G5 (SO-DIMM); EliteOne 1000 G1, 1000 G2, 800 G4, 800 G5, 800 G6; ProDesk 400 G5 (SO-DIMM), 405 G4 (SO-DIMM), 600 G4 (SO-DIMM); ProOne 400 G4, 400 G6, 440 G5, 440 G6, 600 G5
- Capacity
- 16 GB
- Upgrade Type
- System specific
- DRAM memory module
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Speed
- Non-ECC
- Unbuffered
- Voltage
- 1.2 V
- HP Smart Buy
- Designed For
- HP Elite Slice, Slice for Meeting Rooms, Slice for Meeting Rooms G2 for Intel Unite, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 Partner Ready with Microsoft Teams Rooms, Slice G2 with Microsoft Teams Room , HP EliteDesk 705 G4(SO-DIMM), 705 G5(SO-DIMM), 800 G4(SO-DIMM), 800 G5(SO-DIMM) , HP EliteOne 1000 G1, 1000 G2, 800 G4, 800 G5, 800 G6 , HP ProDesk 400 G3(SO-DIMM), 400 G5(SO-DIMM), 405 G4(SO-DIMM), 600 G3(SO-DIMM), 600 G4(SO-DIMM) , HP ProOne 400 G3, 400 G4, 400 G6, 440 G5, 440 G6, 600 G3, 600 G5
