HP 128 Wired Mouse
HP 128 Wired Mouse
Quicklinx: GR6CWS00 Mfr#: 265D9AA
Wired / Wireless: Wired
Colour: Black
Hurry, only 2 left in stock!
£10.20 ex VAT
£12.24 inc VAT
Think how much you use your mouse. That's why we've taken the time to design a laser wired mouse that is comfortable to use so you can work productively every day - and all day if necessary.
  • Designed for comfort
    This mouse includes perfectly positioned left and right buttons and a scroll wheel so you can work in comfort all day. You can even adjust the dot per inch speed of the cursor.
  • Plug-and-Play connectivity
    Connecting some peripheral devices can be a complex and time-consuming task. With easy Plug-and-Play USB connectivity, you can get your laser wired mouse connected quickly so you can get on with your work day.
  • Responsibly made
    You should feel good about the products you buy and use. Rest assured, this laser wired mouse is responsibly made with printed circuit boards that is low-halogen.
  • Easy cleaning
    Use your mouse every day and it will accumulate dirt and grime. Over time, this can affect how it performs. Because it was specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse that's a snap to keep clean.
HP 128 - mouse - black
Mouse
Wired
6.3 cm x 11.2 cm x 3.6 cm
80.5 g
Movement Detection Technology
Laser
Movement Resolution
1200 dpi
Scrolling wheel
Cable Length
180 cm
Mouse
6.3 cm
11.2 cm
3.6 cm
80.5 g
Input Device
Wired
Laser
Movement Resolution
1200 dpi
Cable Length
180 cm
Scrolling wheel
1 x USB
Plug and Play
Colour: Black
Brand: HP
