Think how much you use your mouse. That's why we've taken the time to design a laser wired mouse that is comfortable to use so you can work productively every day - and all day if necessary.
Designed for comfort
This mouse includes perfectly positioned left and right buttons and a scroll wheel so you can work in comfort all day. You can even adjust the dot per inch speed of the cursor. -
Plug-and-Play connectivity
Connecting some peripheral devices can be a complex and time-consuming task. With easy Plug-and-Play USB connectivity, you can get your laser wired mouse connected quickly so you can get on with your work day. -
Responsibly made
You should feel good about the products you buy and use. Rest assured, this laser wired mouse is responsibly made with printed circuit boards that is low-halogen. -
Easy cleaning
Use your mouse every day and it will accumulate dirt and grime. Over time, this can affect how it performs. Because it was specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse that's a snap to keep clean.
 - HP 128 - mouse - black
 - Mouse
- Connectivity Technology
 - Wired
 - Black
 - 6.3 cm x 11.2 cm x 3.6 cm
 - 80.5 g
- Movement Detection Technology
 - Laser
- Movement Resolution
 - 1200 dpi
 - Scrolling wheel
- Cable Length
 - 180 cm
 - Mouse
 - 6.3 cm
 - 11.2 cm
 - 3.6 cm
 - 80.5 g
 - Black
Input Device
 - Wired
 - Laser
 - 1200 dpi
- Cable Length
 - 180 cm
 - Scrolling wheel
 - 1 x USB
 - Plug and Play
