Think how much you use your keyboard. That's why we've taken the time to design a keyboard that is comfortable to use so you can work productively every day - and all day if necessary.
Antimicrobial
Antimicrobial coating helps this keyboard meets Chinese standards for antimicrobial testing.
- HP 125 - keyboard - UK Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- 43.6 cm x 13.8 cm x 2.03 cm
- 1-year warranty
- Designed For
- HP 34; Laptop 15; Presence Small Space Solution Plus AI Camera with Microsoft Teams Rooms, Small Space Solution Plus AI Camera with Zoom Rooms, Small Space Solution with Microsoft Teams Rooms, Small Space Solution with Zoom Rooms; Pro Mobile Thin Client mt440 G3; ZBook Power G8, Studio G9
- Keyboard
- Interface
- USB
- UK
- Region
- United Kingdom
- 43.6 cm
- 13.8 cm
- 2.03 cm
- Cable Length
- 1.8 m
- IEEE 1680.1-2018, Plug and Play, low halogen, FCC, cULus, GS, EAC, BIS, KCC, RCM, BSMI, VCCI
- OS Required
- Windows 10 (32/64 bits)
- Limited warranty - 1 year
- 10 °C
- 50 °C
- 10 - 90%
- Designed For
- HP 245 G9 Notebook, 295 G8, 34, t430 v2, Z1 G8 , HP Chromebook 14 G7 , HP Chromebook x360 11MK G3 Education Edition , HP Elite Mini Conference G9 , HP EliteBook 645 G9 Notebook, 835 G8 Notebook , HP EliteOne 800 G8 , HP Laptop 15s-eq3029nl , HP Presence Small Space Solution Plus AI Camera with Microsoft Teams Rooms, Small Space Solution Plus AI Camera with Zoom Rooms, Small Space Solution with Microsoft Teams Rooms, Small Space Solution with Zoom Rooms , HP Pro Mobile Thin Client mt440 G3 , HP Pro x360 Fortis 11 G9 Notebook , HP ProBook 445 G8 Notebook, 455 G8 Notebook, 455 G9 Notebook, 635 Aero G8 Notebook , HP ProDesk 405 G8 , HP ZBook Power G8 Mobile Workstation, Studio G9 Mobile Workstation
