Think how much you use your keyboard. That's why we've taken the time to design a keyboard that is comfortable to use so you can work productively every day - and all day if necessary.
The Key to AI
With one key, access the power of Microsoft Copilot, an AI powered assistant that helps you simplify tasks, collaborate, and work smarter. Find answers from across the web, personalize your apps, or get creative with text, photos, and videos.
 - HP 125 G2 - keyboard - 100% full size - UK - black Input Device
 - Keyboard
- Interface
 - USB
- Connectivity Technology
 - Wired
- Localization and Layout
 - UK
- Hot Keys Function
 - Num lock, Caps Lock
- Numeric Keypad
 - Black
 - 43.6 cm x 13.8 cm x 2.05 cm
 - 460 g
 - 1-year warranty
 - Keyboard
- Interface
 - USB
- Hot Keys Function
 - UK
- Region
 - United Kingdom
- Keyboard Technology
 - Plunger
- Adjustable Height
 - Numeric keypad
 - 43.6 cm
 - 13.8 cm
 - 2.05 cm
 - 460 g
 - Black
- Cable Length
 - 1.8 m
 - FCC, IC, RCM, BSMI, EAC, UKCA, KCC, VCCI, ANRT, BIS, NRTL, RoHS
- Key Life Span
 - 10 million clicks
- OS Required
 - Windows 11, Windows 10
- Shipping Width
 - 45.3 cm
- Shipping Depth
 - 17 cm
- Shipping Height
 - 2.7 cm
Sustainability Information
- Product Recycled Content
 - Post-consumer recycled plastic
 - Limited warranty - 1 year
