Think how much you use your mouse. That's why we've taken the time to design a wired mouse that is comfortable to use so you can work productively every day - and all day if necessary.
Antimicrobial
Antimicrobial coating helps this mouse meets Chinese standards for antimicrobial testing.
 - HP 125 - mouse - USB - black - Smart Buy
 - Mouse
- Connectivity Technology
 - Wired - USB
 - Black
 - 6.3 cm x 11.2 cm x 3.6 cm
 - 80.5 g
 - Scrolling wheel
- Cable Length
 - 180 cm
- Manufacturer Selling Program
 - HP Smart Buy
 - Mouse
 - 6.3 cm
 - 11.2 cm
 - 3.6 cm
 - 80.5 g
 - Black
Input Device
 - Wired
- Interface
 - USB
- Cable Length
 - 180 cm
 - Scrolling wheel
 - 1 x USB
 - Plug and Play
 - HP Smart Buy
